X pipe diameter?
Old Dec 20, 2006 | 02:50 PM
Hvymtlc5's Avatar
Hvymtlc5
Default X pipe diameter?
Would there be any adverse affect to installing a 3 inch X pipe on a 2.5 inch system? X pipe is on the shelf so no added cost incurred is the reason for asking.
Old Dec 20, 2006 | 02:56 PM
Durango_Boy's Avatar
Durango_Boy
I've heard mixed results from people that installed an X-pipe. Low RPM engines will probably not see much of a gain...at least not worth the install time and effort. For higher RPM operation...I've heard it can help some, and improve sound.
Old Dec 20, 2006 | 05:21 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I put one in to remove low rpm noise as much as for the HP gain at top end. I don't see any reason the 3" wouldn't work.
Old Dec 20, 2006 | 05:42 PM
panic's Avatar
panic
i'd say you could loose some torque numbers at low revs and gain something at higher revs...
Old Dec 20, 2006 | 05:55 PM
Bee Jay's Avatar
Bee Jay
I read somewhere, prolly here, that an ideal crossover pipe is actually larger than the exhaust system size.
Old Dec 20, 2006 | 06:10 PM
MN80Vette's Avatar
MN80Vette
This has been discussed quite a bit on the CF. Do an advanced search. The effect on performance gets mixed responses.
Check out the http://www.popularhotrodding.com/eng...xh/index1.html article for the theory.
As for me, I got a big jump in output from GMPP 350 HO crate his autumn due solely to exhaust changes, but I don't know how much gain came from switching from block hugger headers to full length headers and how much came from the H-pipe cross over I added.
Old Dec 21, 2006 | 09:02 AM
Maymyvetteliveforevr's Avatar
The linky says "The page cannot be displayed" is it me or what?
Old Dec 21, 2006 | 09:08 AM
norvalwilhelm's Avatar
norvalwilhelm
I always thought the cross over pipe should be one size smaller then the exhuast.
I also feel if you are jumping from 2 1/2 inch exhaust to a 3 inch X you would have problems with the transissions on the sizes??
Old Dec 21, 2006 | 01:32 PM
Durango_Boy
Nah, I've seen 2.5" to 3" size adapters at Autozone for a few bucks each. I've gone from a 4" collector to a 2.5" pipe before.
Old Dec 21, 2006 | 01:41 PM
norvalwilhelm
That's not the point. The point is you need 4 of them and it begins to look mickey mouse. No way I would want something like that on my car.
I just want neater work on my car.
Old Dec 21, 2006 | 01:45 PM
Durango_Boy
You're right there, and I agree. It did look awkward with a large step down in size like that.
Old Dec 21, 2006 | 09:07 PM
Jason Staley
Dr. Gas has some nice smooth transitions that could be welded in so the assembly would be tidy looking.
http://www.drgas.com/store/product.p...&cat=14&page=1
Old Dec 21, 2006 | 09:09 PM
Durango_Boy
What data is there to support a bigger size X-pipe will get you better results than a same-size X-pipe?
Old Dec 21, 2006 | 10:02 PM
Jason Staley
I've never seen it, just figured it wouldn't hurt thats all.
Actually, the one I use starts out at 3" and reduces to 2.5". I got it from Dr. Gas so I could run 3" pipe up to the x-pipe and then run 2.5" back to my Borla mufflers that I already owned for several years.
Old Dec 21, 2006 | 10:09 PM
David Ey's Avatar
David Ey
don't yall like to see and hear what each side is doing?
Old Dec 21, 2006 | 10:43 PM
Jason Staley
The x-pipe helped eliminate a nasty resonance near cruising speed that I was getting with the Borla's. Before the new exhaust the Borla's sounded like glass packs to me (way too noisy), but after I put the 3" pipes on the car sounds sweet.
Old Dec 22, 2006 | 06:07 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default It depends how restrictive your exhaust is now.
Earlier this year a forum member posted dyno results for his X-pipe and it was approx 5% accross the rpm band. But he was running stock iron exh manifolds too. This was on a GM crate 383 shortblock installation.
So what what i'm saying is that the more restrictive your exh sys is now the more the X-over will help. The more free flowing exh capacity u have now the less improvement u will see.
As for the 2.5" to 3" back to 2.5" it would only reduce restiction and act as more of a balance/resonance chamber and that should be an improvement also.
Just the problem is will it all fit?
Hope this helps and good luck.
cardo0
To X pipe diameter?
Old Dec 22, 2006 | 08:24 AM
Hvymtlc5's Avatar
Hvymtlc5
I'm going to give it a go. Going from 3 1/2 in collectors on the BB header to 2 1/2. 3 " X-pipe will be installed immediately after the crossmember and reduce to a 16" length of 2 1/2, then into the Flowmaster 40s. (everything will stay under the car and not exit the rear).
Old Dec 22, 2006 | 08:46 AM
norvalwilhelm
Are you going to dump the exhuast under the car? If so the gas tank acts as a big drum and dumping the exhuast under there can lead to alot of resonance.
Dumping out the rear at least lets you run away from the noise.
The other problem is dust. If you have turn downs at the end of the exhuast system it really kicks up the dust, clouds of dust and the wilder the cam the more dust you kick up.
Old Dec 22, 2006 | 09:17 AM
Bee Jay's Avatar
Bee Jay
cardo0
Isn't that what a resonator is? An area for the exhaust (and sound) to expand, then reduced back down the exhaust system. It should help with noise and resonance at least. I was considering this myself, but I solved my problem with fatmat (a dynomat knockoff) and felt. Norval brings up an interesting question though, is the gas tank acting as an amplifier? I know my hatch area (79 Vette) was. Is it louder with an empty tank. Anyone have a noise meter?
