Help with motor vacuum
Old Dec 27, 2006 | 12:01 PM
BLAZE69's Avatar
BLAZE69
Default Help with motor vacuum
I am trying to trouble shoot a rapid needle fluctuate between 13" and 16"Hg. while my 350 engine is at idle. On acceleration the needle tends to smooth some but not all bounce is gone. I am taking the reading directly from the manifold and no gasket leaks are found. I am leaning toward valve guide wear but will check any other suggestions. The motor is a basic 350 in my 69 coupe. Thanks, Fred
Old Dec 27, 2006 | 12:14 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
My vote would be valves - but not the guides. Valve guides are out of the combustion chamber. This type of behaviour is most likely due to carbon buildup on intake valves and/or leak in valve seats.
Run a wet and dry compression test.
Old Jan 2, 2007 | 07:33 PM
BLAZE69's Avatar
BLAZE69
Just saying thanks for the info. I will be doing a leak down test this week and it should help me find my problem. Fred
Old Jan 2, 2007 | 07:37 PM
7T1vette's Avatar
7T1vette
I think this can also be a result of having a rather radical cam with some overlap. Other folks who have better engine knowledge can do better with the specifics. If you have a "mild" cam, I would agree with valve leakage.
Old Jan 2, 2007 | 08:33 PM
strokervette's Avatar
strokervette
I would think that if it is a steady fluctuation it would valve related. My 383 has 10" of vacuum at 850 to 900 rpms and 12 at 1000 to 1050 rpms (b/c of the overlap). But mine is steady as a rock at either rpm level. Mine dosen't like to idle very well below 900 so I keep it at 1000. Do a leakdown test and you'll at least narrow down the problem.
Old Jan 2, 2007 | 08:38 PM
SIXFOOTER's Avatar
SIXFOOTER
Usually a fluxing needle like that is a intake manifold to head leak. I wasn't aware that a bumpy cam will do it too.
Learn something new everyday in here
Old Jan 2, 2007 | 08:56 PM
strokervette
Well if I let the idle go down to where it will almost stall then yes the needle will fluctuate, but his idle is around normal and it still bounces a little while accelerating, so I'm still leaning towards a valve related issue. It could also be an atmospheric leak too. Spray some ether around where the intake gaskets are and see if the idle goes up. Heck even try around where the carb mounts to the intake. If there's a leak, the ether entering the system will make the engine run lean and idle will increase.
To Help with motor vacuum
