What is missing from my engine?
Old Dec 29, 2006 | 06:44 PM
HoosierHoopsFan's Avatar
HoosierHoopsFan
Default What is missing from my engine?
I took my new vette to my buddy's house today and he said it should have something over the distributor cap that is missing. I have a 79 L82 4 speed. He had a 80 L82 but traded it in recently on a C5. He can't remember exactly what it is, but said it looks like something is missing there. Can anybody help?
Old Dec 29, 2006 | 07:01 PM
blctalon's Avatar
blctalon
I there is a chrome plate or some type of panel thing that goes over the distributor cap to hide the wires and stuff. It's not required.
Old Dec 29, 2006 | 07:21 PM
azcarguy's Avatar
azcarguy
as said, it's just a little cover, purely cosmetic.
Old Dec 29, 2006 | 07:35 PM
HoosierHoopsFan
Cool. Thanks guys.
Old Dec 29, 2006 | 07:53 PM
Vettkeeper's Avatar
Vettkeeper
Also looks like you’re missing the spark plug wire retainer.
Old Dec 29, 2006 | 07:59 PM
84rzv500r's Avatar
84rzv500r
Actually there is someting missing... it is a plastic ring that snaps to the top of the coil cover and the tabs at the top of all the spark plug boots push into. This was OEM on the big "coil in cap" HEI units. It also help hold the sparkplug wires on in severe duty use.
PS Vettkeeper beat me to it...
Old Dec 29, 2006 | 08:09 PM
Twin_Turbo's Avatar
Twin_Turbo
You're also missing the filter in the brake booster vac line and of course the original air cleaner and snorkel setup
Old Dec 29, 2006 | 08:26 PM
DMONSVETTE's Avatar
DMONSVETTE
You need to get the Accel Super HEI coil, it replaces the stock GM HEI coil and it acts as spark plug wire retainer.
See pics on my webpage.
Looks like you are also missing the radiator seals that sit above the radiator support bracket.
Old Dec 29, 2006 | 09:40 PM
lars's Avatar
lars
Originally Posted by HoosierHoopsFan
he said it should have something over the distributor cap that is missing. Can anybody help?
You're missing the spark plug wire harness retainer that clips into the top of your distributor (available from Mid America), and you're missing the big black plastic distributor cover/wire cover that was used on your year Vette (it was not chrome on the HEI cars). Your distributor is also installed one tooth off, which gives it the "crooked" look: When it's installed correctly, the coil will be "square" in the engine compartment with the engine correctly timed.
Old Dec 29, 2006 | 10:35 PM
marshrat99's Avatar
marshrat99
with Lars. Doesn't hurt anything except the curious.
Old Dec 29, 2006 | 10:50 PM
masterspydog's Avatar
masterspydog
Default missing the **mn AIR pump - smog stuff
misssing the crappy smog stuff - ie AIR pump near the compressor
Old Dec 29, 2006 | 10:53 PM
greyghost79's Avatar
greyghost79
one other thing you're probably missing is..... HORSEPOWER
get some.
Old Dec 29, 2006 | 10:55 PM
HoosierHoopsFan
Geez, heck yes! That's even more than I expected. Thanks guys.
What else off this pic?
Old Dec 29, 2006 | 10:57 PM
HoosierHoopsFan
Not so much thanks to greyghost...
Old Dec 29, 2006 | 11:06 PM
The Spark's Avatar
The Spark
Corvettes had a cover over the distributor / coil to cut down on interference with the radio since the body was made of fiberglass instead of metal. It is not cosmetic. SB engines also had covers over the plug wires from the distributor to the plugs. BB engines used plug wires with braided wire around them and grounded to engine.
Modern plugs and plug wires don't interfere with modern radios near as much so you can get by without the cover. I think it does look nicer with it.
Old Dec 29, 2006 | 11:49 PM
cherrybombc3's Avatar
cherrybombc3
Here is what a 78 had stock on the distributor, as stated earlier it was a shield for electrical interference, not really needed nowadays.
Old Dec 29, 2006 | 11:53 PM
lars's Avatar
lars
That's a good shot of a stock setup showing the black plastic distributor shield. It also shows the power brake booster vacuum line filter that TwinTirbo referred to in his comment above. Good post!
Lars
Old Dec 30, 2006 | 01:03 AM
cherrybombc3
Lars
Awe, it was nuttin.
I just happened to be looking at this site right before I came on here and read the thread.
Lars, all done snowboarding tonight?
Jimbo
To What is missing from my engine?
