Wtf
Dec 29, 2006 | 07:14 PM
Cruise-In IV Veteran
Cruise-In V Veteran
Wtf
How the heck does the tach drive gear come out? The shop manual isnt exactly enlightening.
Dec 29, 2006 | 07:31 PM
Unscrew the large brass housing and the gear comes out, usually with it.
Dec 29, 2006 | 07:35 PM
Cruise-In V Veteran
Standard thread? Special tool?
Dec 29, 2006 | 07:39 PM
It has a slot, although not deep enough to do any good. Leave the tach. cable on and using Channel-lock type pliers, squeeze hard on the cable end and just unscrew counter-clockwise. They can get stuck hard...
Dec 29, 2006 | 07:56 PM
Cruise-In V Veteran
The gear on the main shaft won't allow it to come out. THere's a lip at the top of the housing. What am I doing wrong?
Dec 29, 2006 | 07:58 PM
Once you unscrew the brass bushing, the gear comes out with the bushing. There is nothing retaining it on the inside - there is no lip.
Dec 29, 2006 | 08:02 PM
Cruise-In V Veteran
I got the tach drive gear out. But the gear on the mainshaft wont allow the entire mainshaft to come out of the housing.
Dec 29, 2006 | 08:30 PM
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Could it the area where the roll pin goes through the shaft has a burr and maybe dragging on the lower bushing? Just a guess.
Dec 29, 2006 | 08:37 PM
Ok, the main shaft gear....Yes, burrs on the shaft/gear will cause it to stick, as well as dried oil film. May need to soak it in P.B blaster or similar. Be careful with the bronze shaft bushings.
Dec 29, 2006 | 08:38 PM
Remove the gear
Quote:
Originally Posted by
Eddie 70
In order to remove the main shaft you have to remove the gear that drives off the cam shaft. So remove the roll pin and slide the gear off. The shaft now will slide out.
RonTech
Dec 29, 2006 | 09:32 PM
Cruise-In V Veteran
Well this is great. Now I have a busted distributer
Dec 29, 2006 | 09:35 PM
Cruise-In V Veteran
Luckily it appears that ecklers sells a new upper bushing. So now it appears that I need to figure out how to get the bushing out.
Dec 29, 2006 | 09:48 PM
Cruise-In V Veteran
I found a tool to install the bushing, but how to get it out?
Dec 29, 2006 | 10:14 PM
I use a long 1/4 inch hard steel rod. Catch the edge of the bushing and drive it out.
Dec 30, 2006 | 07:56 AM
Cruise-In V Veteran
Dec 30, 2006 | 01:15 PM
Cruise-In V Veteran
SUCCESS!!
