Testing a transmission fluid cooler.
Old Jan 3, 2007 | 11:06 PM
Durango_Boy's Avatar
Durango_Boy
Default Testing a transmission fluid cooler.
Hi all. My car is gonna get a full range of fluid coolers. Aside from the radiator, I will have a power steering fluid cooler, non-fan...an engine oil cooler, non-fan, and a transmission fluid cooler, fan cooled.
I have a nice big transmission fluid cooler, that was pulled off of my Durango when I had some work done a year or so ago. They claimed it was bad, but the new one wasn't much. Just to be safe I asked for the old one back, and they gladly handed it over.
I was wondering what the line pressure is in a transmission fluid system, and what the best way to test it is. I was thinking of setting it up with threaded, barbed nipples, and rigging it inline of a garden hose. With one end open, turn on the hose and watch for leaks. To test pressure...I would slowly start closing a valve on the end...increasing the pressure within the cooler.
How much pressure does the average house garden hose have, and it it safe to let the cooler go under the full pressure? Is there a better way to test cheaply and myself?
Old Jan 3, 2007 | 11:14 PM
SIXFOOTER's Avatar
SIXFOOTER
Its not a lot, I just saw it on my tranny rebuild video. Under 75. I would have to watch the video again. Your test rig should work
Old Jan 3, 2007 | 11:16 PM
Big2Bird's Avatar
Big2Bird
Pump pressure varies from 60-200 lbs, probably higher on race cars. Pump it up with 100PSI air, spray with soapy water, if it holds, prob okay.
Old Jan 3, 2007 | 11:19 PM
Durango_Boy
Cool...garden hose testing rig it will be. Woo Hoo.
Old Jan 4, 2007 | 04:25 AM
TimAT's Avatar
TimAT
A 700-R4 with the convertor locked and WOT will be from 125 to 150 psi. I can't recall any other GM trannys that get that high.
If you can find a tank to sink it in it would be easier to see the trail of bubbles.
Old Jan 4, 2007 | 09:50 AM
Durango_Boy
That's true, and I am going to do that...but I want to test it under pressure. It may not leak with just fluid in it...and I install it and it leaks under pressure.
Old Jan 4, 2007 | 09:52 AM
TimAT's Avatar
TimAT
Sorry- I was thinking to put it under air pressure and then sink it in a tank.
Old Jan 4, 2007 | 09:53 AM
Durango_Boy
That I could do...not a bad idea at all.
What pressure should I set it to?
Old Jan 4, 2007 | 10:58 AM
GruntyPants's Avatar
GruntyPants
It sounds like if you can show no leaks at 100 psi you should be fine. If you have your outside spigot for your water hose on the 'unregulated' side of your house, then depending on your water supplier you may have upwards of 100psi.. but that varies from city to city. You can get a cheap guage to put on the end of a water hose to check.
The air pressure idea seems the easiest to do, and I build a 'Doctor Seuss' looking rig myself for pressure testing radiators and heater cores (only up to about 12 psi or so though). I made it from PVC with a pressure guage and screwable fittings for the ends to allow large and small hoses. I was able to just watch for pressure drop, and if I see one I spray it down with a soapy water solution and watch for bubbles. Just bring the pressure up slowly as a pinhole can open up quickly under a lot of pressure.
Old Jan 4, 2007 | 11:01 AM
Durango_Boy
Next question. If the leak is in a certain spot, or not very big...is it repairable? It's a free cooler, pretty big, and perfect for use. If it's fixable I would almost like to have that done.
Old Jan 4, 2007 | 03:15 PM
noonie's Avatar
noonie
You can always go to a scrapyard and find an a/c evaporator. Have used those for years for tranny coolers. Work great. Many sizes available too.
Instead of pressure checking, you can also leak check by vacuum. Usually you can find smaller leaks this way too.
Good luck
Old Jan 4, 2007 | 03:22 PM
Durango_Boy
Good luck
I thought about that since I have a few of those lying around...I just like the small compact nature of this one.
Old Jan 4, 2007 | 08:52 PM
Big2Bird's Avatar
Big2Bird
Chances are it is aluminum. If it does leak, the metal is probably fatigued, and you are delaying inevitable failure. Toss it.
"Cooler cheap, tranny $$$$$$$$".
Old Jan 4, 2007 | 11:48 PM
Durango_Boy
Oh I'll toss it if I half too...I just like the design. It fits exactly what I want, and most aftermarket coolers are not like this. It's a Chrysler specific unit that I like a lot.
To Testing a transmission fluid cooler.
