Timing light hookup
Old Oct 1, 2001 | 02:19 AM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
Default Timing light hookup
Where do I hookup the positive line for a timing light?
I know the normal place is the battery...there's the obvious problem of reach.
Is there a place I can hook it up in the engine bay? Right off the alternator or something or do I need to rig up an extension for the positive line?
thanks
Old Oct 1, 2001 | 02:23 AM
Jon69L46's Avatar
Jon69L46
Default Re: Timing light hookup (Chris Fowler '80)
Right at the back of the alt. Positive and negative. Be very careful with the positive, so easy to slip if your not careful.
Old Oct 1, 2001 | 02:30 AM
Chris Fowler
Default Re: Timing light hookup (Jon69L46)
Thanks...figured, but thought I ought to make sure.
Old Oct 1, 2001 | 02:57 AM
Chuck Harmon's Avatar
Chuck Harmon
I like clipping to the horn relay post on the drivers side fender well. More out of the way and less chance of unintentional grounding.
Chuck
Old Oct 1, 2001 | 09:09 AM
Racer-X's Avatar
Racer-X
Default Re: Timing light hookup (Chuck Harmon)
I just run jumper cables from behind my seat, simple and easy. :hat
Old Oct 1, 2001 | 09:16 AM
Gordonm's Avatar
Gordonm
Default Re: Timing light hookup (Racer-X)
I use the horn relay post. Out of the way and no problems with cable length
Old Oct 1, 2001 | 12:20 PM
Chris Fowler
Chuck
Hmm...I'll have to look for that.
Any hints other than "driver's side fender well"? :D
Old Oct 2, 2001 | 11:09 PM
VolVette's Avatar
VolVette
I looked for the horn relay tonight and could not find it?
Anyone want to give a few hints as to where it is?
Thanks,
Stephen
Old Oct 3, 2001 | 10:52 AM
lars's Avatar
lars
Just clip it to the back of the alternator - the positive post is right there, and the ground lug is there, too. Then you have all the wires hooked up right where the #1 cylinder is and the job is a piece of cake. Very quick, very easy. There is no more chance of shorting out the positive clip at this location than at any other location, so it's perfectly safe.
Old Oct 3, 2001 | 04:06 PM
Stoge's Avatar
Stoge
Default Re: Timing light hookup (lars)
Thats where I hook it up at.
To Timing light hookup
