timing issue
Old Jan 8, 2007 | 02:47 PM
tellcom2001's Avatar
tellcom2001
Default timing issue
i have a 79 vette with a 325 hp motor and edelbrock 600 cfm carb. i also have a msd 8365 distributor. im supposed to have a mechanical advance of 21 degrees.and its all in by about 2300 rpms and i set the initial at 15 degrees. but when i step on it she falls flat on her face. lars if your on here please help or anyone that knows how to fix my baby
Old Jan 8, 2007 | 03:01 PM
SIXFOOTER's Avatar
SIXFOOTER
Did you read this?
http://forums.corvetteforum.com/show....php?t=1430339
Old Jan 8, 2007 | 03:09 PM
tellcom2001
yes i read that but i still dont know why its falling on its face when i step on it. under light load it seems good but when i step on it and start to speed up it loses power and bogs down
Old Jan 8, 2007 | 03:24 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Are you sure it's a timing issue? Have you checked fuel delivery, i.e. filter and presure?
Old Jan 8, 2007 | 03:25 PM
SIXFOOTER's Avatar
SIXFOOTER
and accelerator pump operation
Old Jan 8, 2007 | 03:38 PM
tellcom2001
filter and pump are about 6 months old
Old Jan 8, 2007 | 04:06 PM
lars's Avatar
lars
Disregard initial timing and set your total to 36. Once the total is set, run your vacuum advance off manifold vacuum and see what happens. If it still falls on its face, you're likely lean. Check accel pump function and then richen it up.
Old Jan 8, 2007 | 04:26 PM
tellcom2001
okay i talked to atk my engine builder and he said to change the springs in my metering rods on my carb. thinks its lean. thank you lars and everyone for the advice
Old Jan 8, 2007 | 05:21 PM
tellcom2001
changed the springs and now she hits it and gets it. thanks to you all
To timing issue
