4" Stroke
I have not clearanced or even had one but I am getting a custom built crate motor from T&L engines. It has a 4" stroke. Its 408", dart heads and a hyd roller and it makes 520lbs tq. Its like 400lbs at 2500 rpms.
Dennis
yes it is common motor. I have built a few 3.875's which is 396 ci. They just kick the 383's butt's
I know you have done a few 396s, but it would sure be nice to talk with someone who has built the 408.
I was running some numbers on DD2000 last night. With a set of afr heads and solid roller in the range of 240/245 .570 it was pushing 550 hp @ 6000 with peak torque coming at 4500.
Crank 1 Pro-Line Forged 4340 Crank w/4.00 stroke Choose numbers from this key code,
and match them to the kit #'s listed
in the table below.
Example:
Crank #1 + Rods #3 + Pistons #6 = Kit #SKW4401
Crank 2 Callies Magnum Plus Forged Crank w/4.00
Rods 3 SCAT 4340 I-Beam Rod 6.00
(SCAT 7/16 I-Beam Rods add $100)
Rods 4 SCAT/Pro-Line 4340 H-Beam rods 6.00
Rods 5 Callies forged I-Beam rod 6.00
Pistons 6 JE/SRP, Wiseco, PROBE or ROSS forged piston
Pistons 7 Venolia forged piston
Kit # Block Crank # Rods # Pistons
SKW4401 350 1 3* 6 $1569
SKW4402 350 1 3* 6 $1569
SKW4403 350 1 4 6 $1699
SKW4404 350 1 4 7 $1699
SKW4405 350 1 5 6 $1989
SKW4406 350 1 5 7 $1989
SKW4407 350 2 3* 6 $2569
SKW4408 350 2 3* 7 $2569
SKW4409 350 2 4 6 $2689
SKW44010 350 2 4 7 $2689
SKW44011 350 2 5 6 $2949
SKW44012 350 2 5 7 $2949
G
I have a set of srp forged pistons with less than 50 miles on them. So I will try to piece together the bottom end. This project is going to take a while, by parts as I can afford and the machine work. I've found a scat forged crank for 459.00, but I'm still in the planning stage.
I've bought 5-6 stroker rotating kits from Flat Lander racing and one set of heads. They have always been good to me.
another company I used for my first complete 383 was Martel Brothers.
http://www.martelbrothers.com/
The better machine shops have a fixture for clearancing blocks.
I am albout to clearance a OEM 400ci block for a 4 inch crank (427ci ), so I would be interested to hear if anyone has actually done this too
4X4`s with 265`s
Nothing new, 4X4 Small block chevies have been around since shortly after the 265 V8 came out. Which is nearly 50 years of actual 4X4`s usage. They had to figure out what rod to use. 283`s were only slightly better to use
Location: Las Vegas - Just stop perpetuating myths please.
4x4 makes a "square" motor.
And the price is right now too - not hardly and more $$ than a stock stroke. SCAT cranks use the 6" rods too - man the ring pack gott'a be tight.
cardo0
