Differential
Old Jan 13, 2007 | 12:02 AM
Doug Maitlen's Avatar
Doug Maitlen
Default Differential
Do all 79's have a plate under the differential? Do I need it?
Old Jan 13, 2007 | 08:22 AM
Crash80's Avatar
Crash80
The plate that came out of my 80 after a rear end rebuild is sitting in a pile of parts that didn't go back on my car during various projects. If it is the same plate, then the answer is no.
Old Jan 13, 2007 | 10:02 AM
ShinodaVette's Avatar
ShinodaVette
If it is the plate like is on my '81, then it is a heat shield for the diff and the spring due to the tailpipes and mufflers being back here. However, my '81 has the composite spring rather than metal so that may make a difference. I know the VB&P spring replacement comes with its own heat shield and they insist that must be in place for the composite spring. I'll be putting mine back on even with the VB&P shield being there.
To Differential
