chrome paint???
Old Oct 1, 2001 | 11:41 PM
daniel77350's Avatar
daniel77350
Default chrome paint???
Is there a such thing? Also, how does it look? I am about to do the interior, and part of that will be the speedo and tach bezzles wth the chrome, and it looks pretty bad. what, if anything, can I do to freshen up all the chrome on my car? (t-top bar, door handle, door trim, outer door handle, any and all chrome). I want it to shine like my new paint job.
Daniel
Old Oct 1, 2001 | 11:45 PM
Chuck H.'s Avatar
Chuck H.
Default Re: chrome paint??? (daniel77350)
YEP.
Krylon with the shiny silver cap. Other brands, too.
Works well on plastic that has "chrome" on it. Don't recommend for metal like door handles and t-top bar. Use light coats to prevent running.
Chuck
Old Oct 1, 2001 | 11:46 PM
jeffnles1's Avatar
jeffnles1
It may work OK on the bezels, but I doubt if it'll look right on the other parts you mentioned. It just doesn't look like chrome on a big area. I tried it on some sidepipe covers and it just didn't look right. I sanded it all off and went to an aluminum paint which looks more like brushed aluminum and is OK.
Hope this helps.
Jeff
Old Oct 1, 2001 | 11:52 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
I agree don't paint the metal. Especially the t bar, the ends are chrome but the middle is stainless.
Old Oct 1, 2001 | 11:58 PM
Chuck H.'s Avatar
Chuck H.
Default Re: chrome paint??? (jeffnles1)
Jeff is right.
Works on small areas of plastic trim where the "chrome" is just an accent. Trying to do total coverage does not look good.
Chuck
Old Oct 2, 2001 | 12:12 AM
daniel77350
Default Re: chrome paint??? (Chuck H.)
then how would I freshin up metal chrome?
Daniel
Old Oct 2, 2001 | 12:24 AM
LAvetteman's Avatar
LAvetteman
This is what I did to my t-top trim. I had the chrome pieces rechromed and the stainless middle buffed and polished. The two end caps that go in the corners (top of windshield) you can replace with new ones for the same price with better results. The rear wings (that are riveted to the middle) are no longer available, so have those rechromed.
Old Oct 2, 2001 | 12:25 AM
Mayo_007's Avatar
Mayo_007
Look in the yellow pages, I called a place about recoating hooker sidemounts, and they said they do rechrome, but nothing that big. I did not get details since they couldn't do what I needed. Might be worth a shot, might not.
I later found a place that could do big jobs, but it was cheaper to buy two new sets of sidemounts than have one set redone. Pretty steep!
Good luck
Old Oct 2, 2001 | 01:09 AM
MassVette's Avatar
MassVette
Here's a trick used by detailers--use Testor's silver enamel for models. Apply with small sponge brush---- looks just like the original trim. :chevy
Old Oct 2, 2001 | 01:35 AM
Jenny's Avatar
Jenny
Default Mothers
I used Mothers aluminum/chrome polish on my t-tops it looks MUCH MUCH better now, the sun reflects off of it nicely, and it shines... now if i could get my paint job to match the t-tops .
To chrome paint???
