spindle installation help
Old Jan 16, 2007 | 09:43 AM
discglide's Avatar
discglide
7th Gear
Default spindle installation help
Hello:
Does anyone have any advice or detailed instructions on installing a rear spindle on my 1978 Vette?
I have the new spindle, shim bearings etc
All help will be appreciated.
Regards,
Discglide
Old Jan 16, 2007 | 10:20 AM
78vettespender's Avatar
78vettespender
Try this out:
http://www.corvettefever.com/howto/36458/index.html
You're going to need a rear spindle press to remove the old spindle. Mid America sells it for $199.99. You'll also need the wheel bearing set up tool (Mid America $79.99). Not a job for the faint at heart. Good luck!
Old Jan 16, 2007 | 05:57 PM
GTR1999's Avatar
GTR1999
This is an involved job that requires setting the endplay to .0015-.002". You will need a setup tool as well as some other tools. I always use a surface grinder to dial them in as well. If you do a search here you'll find a lot of info on the job. I posted a lot of pictures on the job in the past so you should be able to find them.
To spindle installation help
