Brake Caliper Spring Elimination
Old Jan 29, 2007 | 05:47 PM
  #41
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Originally Posted by Schwee
I left the springs out just to make it easier to slip the pads in when doing the final assembly. Seems that, for one reason or another, I'm often pulling the calipers. With springs installed, this was always a three-handed hassle.
My '81 is a daily driver and, after two years with new brakes and no springs, not a single brake problem...
Are you using o-ring or oem seals?
  #42
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I rebuilt my calipers several years ago with Orings. When I did I left the springs out also. It was my understanding that the spring is there to keep the piston from rocking in the bore. I have had no problems yet with this setup and it has been around 4-5 years.
Old Jan 29, 2007 | 06:20 PM
  #43
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Originally Posted by Jud Chapin
Thanks for the info but I'm wondering if you've had these Zero Tolerance calipers installed for 15 years without any leaks.
It may even be longer than that.
I replaced the lip seals a couple times within a two year period only to have them leak again. I found an add for Zero Tolerance o-ring pistons in one of the Corvette mags and gave them a call. I talked to the owner of the then new company, who assured me my leaky caliper problems were over.
So far so good.
edit,
Found my invoice for the pistons 8/15/94
Old Jan 29, 2007 | 06:26 PM
  #44
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Why not just buy the "clip" piston tools sold by every Corvette vendor? Seems like a better idea than removing parts that were put there for a reason.
Old Jan 29, 2007 | 08:50 PM
  #45
wombvette's Avatar
wombvette
I dont think those little springs are going to do much for the pistons rocking in the bores. But, they do keep a little pressure on the pads to keep them warm and dry in wet conditions. I think that is more important than the rocking issue. On that same note, the ones I see with problems are those that have been doped up with silicone or other brake quiet products. These materials make the piston rock when the brakes are applied and cause many problems of wear and leaking.
Old Jan 30, 2007 | 09:08 AM
  #46
Schwee's Avatar
Schwee
O-Ring.
Like I said. No problems; no complaints.
Old Jan 30, 2007 | 09:09 AM
  #47
Jud Chapin's Avatar
Jud Chapin
A lot of great info in this post. Thanks to all.
