Radiator Hoses
Old Jan 21, 2007 | 02:08 PM
PhotoVette1's Avatar
PhotoVette1
Originally Posted by I'm Batman
The current AC Delco replacement valve is a plastic unit that seals much better than the original metal valve.
I use the current plastic one in mine.
Old Jan 21, 2007 | 02:19 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Originally Posted by HT1663WB
If I disconnect the heater core will the car be cooler inside in the summer? I normally only drive the car during the summer. Once in a while I'll take it out in the winter but you dont have to turn the heat on it gets hot inside on it's own.
It may or may not be cooler depending on how well the flapper door seals seal. If it seals well, you will not notice any difference. If you are not concerned about heat in the winter, I would disconnect the heater hoses.
If your interior is getting hot on it's own as you say, check the seal on the rear of the hood. This is there to prevent hot engine compartment air from entering the cowling and your vent system. The difference this $8.00 seal can make is enormous and is an easily overlooked item. Without even looking at your car, if that seal hasn't been replaced in the last couple of years, I'd bet that it is at least one of your problems, if not the only one. You can check it by putting a little greese all around the surface and then shutting the hood. When opened, if the greese is not fully transferred to the sealing part of the cowling, that is your problem. Good luck!
As a side note, the '75's did not have a heater control valve.
Old Jan 21, 2007 | 02:26 PM
75 Hot One's Avatar
75 Hot One
My '75 which does not have A/C has a heater hose control valve. It's OEM equipment- copper.
Old Jan 21, 2007 | 02:33 PM
Jud Chapin's Avatar
Jud Chapin
Strange that's on a non a/c car as the purpose of the valve is to block water flow to the heater when the a/c is on. In any event, the '75 a/c car I had did not have one and I naturally thought someone had removed it. However, I checked the AIM manual and it shows they didn't come with one.
Old Jan 21, 2007 | 02:46 PM
75 Hot One's Avatar
75 Hot One
Warm air used to blow even with the valve closed. The valve is vacuum controlled & operation is linked to the heater door opening, I believe. I'm surprised that an A/C & non A/C car would be different.
Old Jan 21, 2007 | 02:56 PM
Jud Chapin's Avatar
Jud Chapin
The only thing I'm going by is the AIM manuals. The '76 shows one and the '75 doesn't. If you have warm air coming from the vents, though, check the rear hood seal as I mentioned above. With the a/c off in my '76, the temperature from the vents was over 100 degrees after full engine warm up. I replaced the hood seal, and the temp dropped to 75 degrees, which was the outside temp. My a/c now blows at 40 degrees, the coldest it's ever been, and I bought the car new.
Old Jan 21, 2007 | 05:07 PM
75 Hot One's Avatar
75 Hot One
I checked my Assembly Manual- P.129- shows a heater control valve for all '75's. Maybe you're not reading the manual right. P.129 applies to 1YA00 which means all models. Coolant control calve is shown in the hose assembly.
Old Jan 21, 2007 | 07:40 PM
clintwilson's Avatar
clintwilson
The only thing auto zone has ever had for my vette is rotella-t. Not even a dome or dash light bulb.
Old Jan 21, 2007 | 08:56 PM
Durango_Boy's Avatar
Durango_Boy
They do come in handy for a few things but for the most part I shop at the other local places.
Old Jan 21, 2007 | 09:34 PM
rudolph schenker's Avatar
rudolph schenker
Originally Posted by Durango_boy
I would avoid Autozone too, so I agree. Oreilly and Napa are local places, and both have quality hoses.
Old Jan 21, 2007 | 10:34 PM
75 Hot One's Avatar
75 Hot One
I wouldn't put too much faith in NAPA. I got both the upper & lower hoses from them. They didn't have them in stock-had to order them in but said they were Gates. The upper hose was fine-had the Gates name stencilled on it & was a nice stiff rubber. The lower hose had no ID on it, was a bit on the soft side & didn't have the wire spring inside. The NAPA guy argued up & down that it was the correct hose but I know otherwise.
Old Jan 21, 2007 | 11:32 PM
Jud Chapin's Avatar
Jud Chapin
I'm a little confused here and maybe you can help me out. Where do you see that 1YA00 means all models? I'm looking all over the manual and can't find the definition. Anyway, page 129 is a non a/c car. If you flip the page over to page 130, you'll see an a/c model with no valve which is the way my '75 a/c car came. There it says both 1YA00 and C60 for heater hoses. I know that C60 is the RPO # for a/c. Are you sure 1YA00 means all models? Take a look at page 132, for example, as it shows 1YA00 and it is a picture of a convertible top. Perhaps I'm misunderstanding something here. Anyway, thanks for the info and maybe you can straighten me out on this.
Old Jan 22, 2007 | 11:17 AM
  #33
Durango_Boy
Napa, as well as most other stores...carry two grades of parts. They can GET the original correct hose, but HAVE a cheap repro with no spring and poor quality. A GOOD car guy employee would have just said we can order the correct hose and have it here by tomorrow. Sounds like you talked to someone from the shallow end of the gene pool.
Old Jan 22, 2007 | 11:56 AM
  #34
75 Hot One's Avatar
75 Hot One
1YA00 is defined on P.8. It does look confusing. P.130 definitely shows no coolant control valve for A/C cars. I conclude that non A/C cars like mine had a control valve while A/C cars had no valve. That must mean that "all models" refers to both coupe & convertible but then the designation on P.132 is confusing. My coupe didn't come with a convertible top. The only other explanation is that "model" referes to either coupe or convertible or there's an error/misprint in the manual.
Old Jan 22, 2007 | 12:06 PM
  #35
75 Hot One's Avatar
75 Hot One
Looking at the manual again, it seems there is an error in the designation on P.132. It says the convertible top is on both the coupe & convertible (1YA00). It should say 1YZ67. Refer to pages 81 & 82 which show windshield details for coupe & convertible. P.81 refers to 1YZ37 (coupe) while P.82 refers to 1YZ67 (convertible). Using that as a base, it seems that P.132 is in error. Note that the text on P.132 (top left) does refer to 1YZ67.
Old Jan 22, 2007 | 12:38 PM
  #36
Jud Chapin's Avatar
Jud Chapin
The more I look at this, Hot One, I think 1YA00 indicates Corvette which may or may not mean all Corvettes depending upon whether the pic pertains to an option. If it does, then there is a RPO # following it. In fact, on many of the pages it will show 1YA00 followed by either "all" or the RPO #. I just looked at my '76 AIM and it also shows the a/c heater hose on the page as 1YA00 followed by C60 which is the RPO # for a/c. Anyway, I think I've spent enough time on this so thanks for input and we'll chat with you later. Jud
Old Jan 22, 2007 | 10:22 PM
  #37
JackDidley's Avatar
JackDidley
I normally hang out in C4, but thought I would add my 2 cents here. In 1980 I bought a low mile 75 AC coupe. No control valve. I thought it was odd, so I added one. I currently have an 80, with one in each hose. I am not sure of the point in that either.
To Radiator Hoses
Old Jan 23, 2007 | 12:24 AM
  #38
Jud Chapin's Avatar
Jud Chapin
Yes, I'm not sure why they put one on a non a/c car but not on one with a/c. In any event, the a/c cars had one in '76. Out of curosity, how did you hook up the vacuum for the '75 switch? It should block the water flow only when the a/c is on as is the case with my '76.
Old Jan 23, 2007 | 06:28 AM
  #39
PhotoVette1
I have never seen any car--whether it be a C3 or an old Datsun that didn't come with a water valve of some sort.
Old Jan 23, 2007 | 07:21 AM
  #40
Glassbowtie77's Avatar
Glassbowtie77
Wherever you decide to buy your hoses from just make sure that the bottom hose yo buy has the spring in it or it will collapse on you and cause overheating problems. Also I would leave the valve in even though you don't want to use your heater because I think you may need it when you want to use your defroster's right? Doesn't the A/C compressor cycle on when you put on the A/C like in these newer cars? I don't know for sure because my car had the A/C removed from it before I bought it. The valve is in there but the vacuum line to it was disconnected so I replaced the valve and now I have all new vacuum lines to put in the system including the one to the valve. Am I wrong on this one, do I not need to do this?
