Radiator Hoses
Old Jan 19, 2007 | 10:02 PM
HT1663WB's Avatar
HT1663WB
Default Radiator Hoses
Anybody know if you can get a cooling system hose kit for a 1977 Vette or do you have to buy them separate?
Thanks, Bill
Old Jan 19, 2007 | 10:08 PM
72LS1Vette's Avatar
72LS1Vette
Try docrebuild.com
Other vendors carry them as well. You can find hoses at NAPA also.
Rick B.
Old Jan 19, 2007 | 10:09 PM
Durango_Boy's Avatar
Durango_Boy
Thanks, Bill
Napa's and Oreilly's both have the correct hoses.
Old Jan 20, 2007 | 07:38 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Thanks, Bill
Don't believe I've ever seen a kit for all the water hoses together.
Old Jan 20, 2007 | 11:24 AM
Durango_Boy
No I have not either and you probably won't find one. There were just too many kinds and combinations based on year and model. Individually isn't all that hard considering there are really only four main hoses.
Old Jan 20, 2007 | 11:44 AM
HT1663WB's Avatar
HT1663WB
Thanks guys.
Old Jan 20, 2007 | 03:31 PM
71rdster's Avatar
71rdster
I don't think anyone sells them as a kit. Your local parts store (Napa, Autozone, etc.) should be able to get them for you. If you want NCRS correct, go with Dr Rebuild or other Vette vendors carrying the correctly marked hoses.
Old Jan 20, 2007 | 08:35 PM
72LS1Vette's Avatar
72LS1Vette
Autozone is pretty hopeless for radiator hoses for C3s in my experience. My 72 has the aluminum radiator and they had one part number for all 72s. I went to at least 3 Autozones looking for the right hose and even after cross-referencing they came up with the wrong hose. Even Napa couldn't come up with the right upper hose.
I would look to one of the Vette specialty suppliers for hoses.
Rick B.
Old Jan 20, 2007 | 08:38 PM
Big2Bird's Avatar
Big2Bird
I recommend Gates or GM. I have bought Autozone Chinese hoses, only to have them fail in 1 year.
Old Jan 20, 2007 | 08:56 PM
Durango_Boy
I would avoid Autozone too, so I agree. Oreilly and Napa are local places, and both have quality hoses.
Old Jan 21, 2007 | 07:58 AM
Jud Chapin's Avatar
Jud Chapin
Yes, I would recommend a brand name hose and stay away from Auto Zone, Advance, Pep Boys, Etc.
Old Jan 21, 2007 | 08:01 AM
PhotoVette1's Avatar
PhotoVette1
Ecklers (actually) has a good price on the ACDelco radiator hoses--I just installed the upper and lower yesterday--they were perfect.
Installation note: I have long since discovered that the nly way to make the lower radiator hose install go easier is to put the end of the hose in boiling water for about ten minutes. Then run out to the car and shove it on before it cools off.
Old Jan 21, 2007 | 11:05 AM
HT1663WB's Avatar
HT1663WB
Thanks guys for all the info.
I have another quick question regarding the cooling system. My C3 is a 77 4 speed, it did have A/C at one time. The heater control valve is original and leaking. Because the Vette no longer has A/C can I just run the hose straight through?
Old Jan 21, 2007 | 11:11 AM
Jud Chapin's Avatar
Jud Chapin
Yes, the function of this valve is to block the hot water flow to the heater core when the a/c is on. You can just remove the valve by replacing the hose. Be sure to block off the vacuum line which controls the switch.
Old Jan 21, 2007 | 12:34 PM
PhotoVette1
Except, I'd bet you'd rather not have the heat on all the time in the summer--the air will leak around the flapper doors--best to leave the valve in or get stop valves.
Old Jan 21, 2007 | 12:37 PM
Durango_Boy
Replace it with a new valve, but maybe a manual valve so you can manually shut if off in the summer, and back on in the winter.
Old Jan 21, 2007 | 12:44 PM
Jud Chapin's Avatar
Jud Chapin
There is a valve available that allows you to turn on/off the water flow into the heater core as needed. (I believe he said his is leaking). Since I'm in S. FL, I disconnected my heater core as we don't have much use for a heater. I replaced it once and I ain'ta gonna do it again...PITA.
To Radiator Hoses
Old Jan 21, 2007 | 01:23 PM
HT1663WB's Avatar
HT1663WB
If I disconnect the heater core will the car be cooler inside in the summer? I normally only drive the car during the summer. Once in a while I'll take it out in the winter but you dont have to turn the heat on it gets hot inside on it's own.
Old Jan 21, 2007 | 01:31 PM
Durango_Boy
Basically yes, but only because most systems leak a lot of air around the door, and that pushes hot air into the cabin. Most guys that live in hot areas, remove the heater hoses, and just bypass from one nipple to the other with a shirt length of hose. This removes hot water from the core altogether. If you have cold weather where the Vette is driven, a manual valve will keep hot water out of the heater core in the hot months, and in it during winter.
Old Jan 21, 2007 | 01:32 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The current AC Delco replacement valve is a plastic unit that seals much better than the original metal valve.
