Radiator Hoses
Old Jan 23, 2007 | 08:08 AM
  #41
JackDidley's Avatar
JackDidley
Originally Posted by Jud Chapin
Yes, I'm not sure why they put one on a non a/c car but not on one with a/c. In any event, the a/c cars had one in '76. Out of curosity, how did you hook up the vacuum for the '75 switch? It should block the water flow only when the a/c is on as is the case with my '76.
I just put in a manual valve. Not NCRS but it was functional. I did not give it much thought at the time, just did it. Seems like a T in the vac line for the heat/ac door could operate the valve also.
Old Jan 23, 2007 | 11:07 AM
  #42
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Thanks for the info.
Old Jan 27, 2007 | 02:15 PM
  #43
Durango_Boy's Avatar
Durango_Boy
I installed a valve that has a threaded outlet and a cap. The threaded outlet is the same size as a male water hose end so you can flush a system with a garden hose easily.
Old Feb 16, 2007 | 06:02 PM
  #44
billsfan's Avatar
billsfan
Originally Posted by I'm Batman
The current AC Delco replacement valve is a plastic unit that seals much better than the original metal valve.
Is the control valve normally open, and closed when the a/c is on, or is it normally closed, and opens when the heat is on??
Old Mar 17, 2020 | 06:43 PM
  #45
chiefpowell's Avatar
chiefpowell
Default heater hose kit for a 1975
Corvette Central has the kits.
Old Mar 17, 2020 | 10:07 PM
  #46
Mooser's Avatar
Mooser
Hopefully he isn't still waiting
M
Old Mar 19, 2020 | 12:57 AM
  #47
carriljc's Avatar
carriljc
Autozone has been very useful for me. They'll try to find what I want and usually succeed. Otherwise I find it at home and bring an image. They've been able to order and obtain just about any generic part (hoses, belts, lamps, etc) that I've required.
I say Autozone because it's the nearest to me. I've actually had pretty good luck with most places.... really helps nowadays to find the part number yourself and then take it with you.
Old Mar 19, 2020 | 03:12 PM
  #48
chiefpowell
I did go to Autozone but there wasn't anyone there that was able to help.
Thank you for the reply..
Old Mar 19, 2020 | 06:36 PM
  #49
HeadsU.P.'s Avatar
HeadsU.P.
M
I thought MY internet, was slow at responding. Good grief. 13 yrs?
Old Mar 23, 2020 | 04:23 PM
  #50
chiefpowell
Default 76 heater control valve
Does it go on the water pump hose or the one going to the manifold?
