Source for Carpet
Old Jan 26, 2007 | 08:42 AM
gregc3's Avatar
gregc3
Default Source for Carpet
I am finally getting to the interior of my '69 and will need to replace the carpet. I wonder what vendors people have had good experiences with. Also do people put anything under the carpet?
greg
Old Jan 26, 2007 | 08:59 AM
psw5940's Avatar
psw5940
I'll have to dig through some paper work to find the name of the comp. I got my carpets from.
But the ans. to the second part of your question is , yes. Do put a sound deadner and heat shield under the new carpet. I used some stuff I got from a local shop, that has "jute" on one side and foil on the other. It made a big difference in the amount of heat and noise you get inside the car.
Many here on the forum use a veriaty of stuff, I'm sure you'll get a lot of good ideas.
Old Jan 26, 2007 | 09:01 AM
JUSBAD's Avatar
JUSBAD
Willcox, vendor here on the forum.
Old Jan 26, 2007 | 09:05 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Al Knoch has quality products.
Old Jan 26, 2007 | 09:39 AM
Jim Martley2's Avatar
Jim Martley2
The first set I installed in my 82 was in 1998. They were from Auto Custom Carpet. They faded from a Dark Red to a Bright Orange in 4 years! When I called them to inquire about this they said "Do you expect them to last a lifetime for our price?" My wife paid $250 for the set.
I bought the replacment set from Al Knoch for about the same price and the fit was a WHOLE bunch better and the carpet appeared to be more plush. They have been in the car for 5 years now and STILL look new.
Old Jan 26, 2007 | 09:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sharks run a bit warm anyway, so most folks install a heat barrier (aftermarket kits or DIY) under the carpet. It helps.
Old Jan 26, 2007 | 10:18 AM
1fastC3's Avatar
1fastC3
another for Al Knock interiors, may take a little trimming but all around good stuff.
-alex
Old Jan 26, 2007 | 11:51 AM
candacedianne's Avatar
candacedianne
The Last Detail in Atlanta, GA has great prices and good quality stuff.
Old Jan 26, 2007 | 11:55 AM
markdtn's Avatar
markdtn
Al Knoch. ACC is OK, but their customer service leaves some to be desired.
Old Jan 26, 2007 | 11:58 AM
ajrothm's Avatar
ajrothm
I just installed some of my carpet from ACC. The fit is crap and the quality is worse. It took me a full day just to get the rear compartment carpet to fit and look right. Lots of trimming, and gluing. I got the 80/20 loop and after gluing it all in and rubbing out the wrinkles etc with my hands, my carpet is now all "furry". After vacuuming it, it looks even worse. It almost looks like old wore out carpet, not the nice, tight loops that it should look like.
I would get the carpet from Al Knoch.
Old Jan 26, 2007 | 12:01 PM
C3 4ME's Avatar
C3 4ME
I would say Al Knoch also.
Old Jan 26, 2007 | 12:25 PM
75 Red Vert's Avatar
75 Red Vert
To Source for Carpet
