Alternator Swap Help Paper.
Old Jan 30, 2007 | 11:57 AM
markdtn's Avatar
markdtn
I am curious why people do this swap. Those alternators had a very poor service life. C4 owners used to joke about carrying a spare on a trip. Have the rebuilds fixed the problems? I went through 3 from Advance on my IROC in 15k miles until I bought a Delco rebuilt; it was on it when I sold it. On my Suburban it had been replaced when I got it at 105k, I replaced it around 150k. I'm not downing your paper, just curious if these alternators have improved over time.
Old Jan 30, 2007 | 12:00 PM
Durango_Boy's Avatar
Durango_Boy
If you get the GM correct Delco parts and you get new and not refurbished it will last a long time. I do think they are better now than they were...
...also keep in mind he swap can be done using a CS144 instead of the CS130 with minor changes to only the upper adjustable bracket.
Old Jan 30, 2007 | 11:10 PM
Z-man's Avatar
Z-man
Originally Posted by Restorod '79
What's the difference between CS and SI, and what's the advantage?
In other words--Why would I be interested?
If you aren't doing a numbers matching restoration, a lot of the guys are adding new electronic equipment such as electronic fans, water pumps, AC, fuel injection, halogen headlights, stereos, GPS, ignitions, etc. The demands of this new equipment far exceeds the old alternators. Upgrades like this just make sense. You can often get these alternators from junk yards but they aren't simply plug and play. He's just documented the steps needed to make the swap.
Good paper Yukon_Boy...oops...Durango_Boy.
Old Jan 30, 2007 | 11:17 PM
Big2Bird's Avatar
Big2Bird
I believe you answered your own question.
Old Jan 31, 2007 | 08:49 AM
Big2Bird's Avatar
Big2Bird
Originally Posted by turtlevette
I have a paper for you to read but i don't think you can handle the equations.
Must be top secret. Kind of like weapons of mass distruction.
Old Jan 31, 2007 | 09:58 AM
Durango_Boy
Heh heh, I'm glad he doesn't have any of those. If he woke in a bad mood one..day...buh bye Chicago.
Old Jan 31, 2007 | 01:11 PM
BerniesVette's Avatar
BerniesVette
I have a CS144 from a Caddilac that I had rebuilt, the serp pulley removed and a new vee type pulley installed. I will sell it for $100.00
(my cost) plus shipping, if anyone is interested.
Bernie
Old Jan 31, 2007 | 02:46 PM
Artsvette73's Avatar
Artsvette73
D B
Was this before or after the cs130 alternator?:
Old Jan 31, 2007 | 03:02 PM
Durango_Boy
Originally Posted by Artsvette73
D B
That's Chicago. Never mind. I guess I lost a few of you with that one.
Old Jan 31, 2007 | 04:30 PM
markdtn's Avatar
markdtn
There are at least 2 options for an alternator just like the 69-82 that will plug right in. The 84-85 C4s use a 105 amp version, also police cars and taxis used a high amp version. Loaded out '70s Cadillac, Buick, Pontiac and also school bus (ambulance?) use a larger version of the original-over 100 amp-but the mounting is different (2 ears instead of a boss on the bottom). The original 69-82 alternators are pretty reliable, I have seen many go well over 100k miles. They are also used on lots of equipment and tractors. For my money, I'll not use that version alternator if I can help it.
I used the 84-85 C4 alternator on my car with the 91 TPI engine conversion. I have electric fans and other electronics.
Old Jan 31, 2007 | 04:33 PM
Durango_Boy
That's the beauty of a swap like this. You can do it if you want to but no one's forcing any hands here.
It's all optional...
Old Feb 1, 2007 | 07:56 AM
BerniesVette
I have to say that I would take the CS144 evey time. I looked at the CS130s and even talked with Madd Elec. and he said the 144 was a much better choice. That being said, I have seen many CS130s give excellent service. I bought a CS144 out of a Caddy and had it completely rebuilt. If I don't sell it I can always use it for a spare for my 92.
Bernie
Old Feb 1, 2007 | 10:37 AM
  #33
Durango_Boy
What I like about the CS130 is it's size, and if it's not over worked you'll get many good years out of it. Not to mention value. You can buy a brand new one for $70.
Old Feb 1, 2007 | 12:17 PM
  #34
mrvette's Avatar
mrvette
Wow we have a lot of electrical engineers on board. That's actually very comforting.
PLUS ONE rather advanced Engineering Tech.....who looks down your throats as to what works and what don't.....
DB I correct insofar as his paper/instructions are concerned...no question....MY problem is, the referance to the CS130 alt....it was a POS from the git go from the factory.....that much I KNOW.....the thing suffered from inadequate cooling, IMO, the case was too small, couldn't get the air through it.....and above any headers or exhaust it had a very short service life....
things supposedly got much better when the redesigned it into the Cs144, but I don't have any experiences with it....so can't honestly comment.....
I have a 17SI unit, and it's good to 108 amps, with lifetime warrenty from AZ.....hehehehehe...snicker....this last one has lasted 2 years....
I admit their rebuilds are crappy sometimes....methinks from vague memory the rebuilder brand changed this last go round....
at any rate, a larger diameter alt will have superior cooling to anything smaller,....screw the fans.....
Old Feb 1, 2007 | 12:58 PM
  #35
BerniesVette
Cooling is the biggest issue with the CS130s. The CS144 is far superior in design and output. Bit I have seen CS130s give good service in stock applications. But I would pay extra to get a CS144.
Bernie
Old Feb 1, 2007 | 01:06 PM
  #36
Durango_Boy
Bernie
I agree...and I probably would have spent the extra money if I had to buy these. But I had three spare ones I got for free. Two of them new. Can't beat free.
Old Feb 1, 2007 | 01:37 PM
  #37
DR.Jay's Avatar
DR.Jay
Here is a link with pic of the common GM alternators, and some applications.
http://www.extreme4wheelin.com/tech/...ators/tech.htm
To Alternator Swap Help Paper.
Old Feb 1, 2007 | 01:43 PM
  #38
Durango_Boy
Great link.
Old Feb 1, 2007 | 07:54 PM
  #39
markdtn's Avatar
markdtn
Nice link. Thanks!
Old Feb 2, 2007 | 08:24 PM
  #40
captainmorgan's Avatar
captainmorgan
I was looking at a altenator that say's that it has a "10:30 Clock Plug". What does "10:30 Clock Plug" mean?
