Why is Starter grinding when engine is hot
Old Jan 30, 2007 | 07:59 AM
vette blue's Avatar
vette blue
Default Why is Starter grinding when engine is hot
Hi;
1970 454 vette all original, when engine is hot and I shut it off and try to restart her the starter just grinds and makes a terrible noise and doesn't turn the engine over.
However when the engine is cold it starts like a charm.
Would anyone have had a similar experience and know how to remedy the problem??
Thanks to all.
Old Jan 30, 2007 | 08:03 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If you mean the starter just spins (does not engage) and the engine does not turn over, it's time for a new starter.
Old Jan 30, 2007 | 08:16 AM
Hiteck's Avatar
Hiteck
Alot of people with this same experience, including myself. I just fight through it and eventually it cranks. Not a daily driver, so it's not really that often that I have to deal with it. There was a post yesterday about this same exact thing. Just scroll down through the posts. Some pretty good information in that post concerning starters.
Old Jan 30, 2007 | 09:01 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The starter drive is probably worn. Less likely is a worn flywheel or both.
Old Jan 30, 2007 | 11:08 AM
Durango_Boy's Avatar
Durango_Boy
Very true, but it's always possible that one of the times the gears were not hooking up properly a few teether were ground off of the flywheel. I would get under the car with the inspection cover off, and turn the crank watching all the teeth until you can say for sure the problem lies only with the starter
Old Jan 30, 2007 | 11:30 AM
bb69's Avatar
bb69
I went through a similar problem and ended up replacing the starter when the gear broke into multiple pieces. My problem was related to the old wiring. The starter gear was not engaging all the way because the solenoid was not getting full voltage because of bad grounds and old wires. The end result was the starter gear and flywheel keep banging into each other until the starter broke. At the same time, I was having ignition problems; the car would not run above 3000RPM.
I know mine was extreme, but this progressed VERY quickly. The car had none of these signs one day, and after one and half sessions at the track (roadcourse) the above happened. I have since rewired all of the power distribution and installed relays for the headlights, and the problems are gone for good. And, I got a new mini starter out of the deal.
Good luck
Ken
Old Jan 30, 2007 | 11:43 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
You need to shim the starter. Start with an .020" starter shim. Your local parts counter can sell you a package with various sizes.
When she's hot, everything expands and the starter gear isn't clearing the flywheel ring gears and grinding instead. It's probably 'barely' clearing when cold.
Good luck!
Old Jan 30, 2007 | 01:36 PM
7T1vette's Avatar
7T1vette
Chances are the Bendix drive on the starter shaft is wearing out. You don't need to replace the whole starter, just the Bendix. They are relatively inexpensive and you can get them at any NAPA store (stay away from gypo parts on the starter). If you can remove the starter from your engine, you won't have any trouble swapping out a Bendix.
Old Jan 30, 2007 | 08:50 PM
vetteaddic's Avatar
vetteaddic
Check all your wire connections,like the ground wire and terminals,also check the ground strap to the motor,
Had a old chevy pickup that did the same thing,changed starters and shimmed and flywheel.worked fine when it cooled but once running and hot ,try to start made a horrorible noise,
Old Jan 30, 2007 | 09:20 PM
Ironcross's Avatar
Ironcross
Some of this information is good and some is bad. Shiming a starter away from the ring gear is not always a good idea. Many may not realize this fact but the engine almost always stops in the same position every time. Damage to the ring gear and starter drive most always is related to attempted or more often by accident, starter engagement while the engine is still running. However for a engine to crank cold ok and when hot it grinds and makes noise does not make any sense. I would think a check or inspection of the flywheel ring gear is in order.
Old Jan 31, 2007 | 12:36 AM
73, Dark Blue 454
Iron-cross,..you're aware that a large percentage of Chevy starters in the day were shimmed at the factory,..back when tolerances were fatter. Plus, many after-market starters for 60's and 70's cars will include shims.
Old Jan 31, 2007 | 01:07 AM
Ironcross's Avatar
Ironcross
Yep I sure am. So, that does not mean that every car needs them. Probably less than 10% would require a shim. We do place them in the boxes so as to avoid any problem with the sale. Even our service center rarely use a shim and only occasionally with a SB 350 starter. Did you know there is also a shim for a Ford starter? Rarely sell those either. But we have them. Heres one for you, Did you ever see a shim made out of a 2X4? The owner applied his own fix, it actually had a bad ring gear.
"Winning isn`t everything, it`s the only thing"
Old Jan 31, 2007 | 07:31 AM
Jud Chapin's Avatar
Jud Chapin
Before you start replacing parts in your starter, keep in mind that you can get a remanufactured one with life time warranty from Advance for $30-$40.
Old Jan 31, 2007 | 07:45 PM
vette blue's Avatar
vette blue
$40 That's great! I'll give it a try and examine the flywheel while I'm at it and inspect the starter gear to flywheel contact to see if shimming is needed.
Thanks to everyone.
Old Jan 31, 2007 | 08:42 PM
Phlash's Avatar
Phlash
If it is an all original, don't let go of the original starter. Even if you buy a new one, keep to old if you want to have a path back to a truly numbers matching car.
Phlash 72 BB Roadster
Old Jan 31, 2007 | 08:43 PM
Durango_Boy
Wow they even look at the starter?
Old Jan 31, 2007 | 09:55 PM
TimAT's Avatar
TimAT
I've heard the NCRS guys inspect a car, they really inspect it. Including what you had for breakfast. 2 days ago.
There are lots of Chevys out there that don't have any shims on the starter. But there are also lots of them that do.
To Why is Starter grinding when engine is hot
Old Jan 31, 2007 | 10:29 PM
Durango_Boy
I have never seen a small block with them, but that's not unlikely. Now, every starter I have bought includes them...so some people do use them.
Old Jan 31, 2007 | 10:52 PM
mdjice's Avatar
mdjice
It's one of the problem I had a few days ago.
Someone told me it was because had headers installed and when they get really hot, since the are very close to the starter it ca fry it...don't know if it's true or not. They said I needed a shield betweent the starter and headers.
I got a new starter installed without a shield (would be an extra $70 on a non ending money whole...DUrango boy knows...) and now it starts perfectly fine. Do you have headers on?
Old Jan 31, 2007 | 11:09 PM
Durango_Boy
Yep, I have Hooker side mount headers and side pipes.
