Husky Air Compressor
Old Feb 14, 2007 | 08:08 PM
stinger12's Avatar
stinger12
bump
Old Feb 14, 2007 | 08:30 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
heres the specs that will unit will work well for you
A solid CAST IRON, twin cylinder compressor pump for extreme durability. Offers 135 PSI maximum pressure and air delivery 11.5/10.2 SCFM @ 40/90 PSI. It also has a space saving vertical design that is perfect for your home garage or work shop.
• Up to 5,000 hours of extended life
• A CAST IRON oil-lubricated pump with traditional design that is quieter and longer lasting
• 60 Gallon vertical, space saving tank design
• Powerful, 3.2 running horsepower motor provides significant air to multiple power tools
• Automotive style changeable air filter
• Protective belt guard
• High quality oversized gauges
• 1070 Pump RPM
• Three-year limited warranty
• Over 35 percent quieter and 60 degrees cooler than aluminum pumps with cast iron sleeves
Internet/Catalog #100083906
Store In-Stock SKU # 710098
Old Feb 14, 2007 | 09:54 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Originally Posted by MYBAD79
I also have this 60 gallon unit from HD. I only paid $399 USD, that's a lot less than $700 CAN as far as I think to know ..... what's the current exchange rate ?
The Husky compressor is great
Did the same thing.....very satisfied. It is actually quiet and runs everything I need in a home garage setup. Just be sure you can add another set of breakers to your breaker box. I hardwired mine.
Old Feb 14, 2007 | 11:32 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I use my dryer wall outlet for the compressor
works fine - I bought another dryer cable so now I have to unplug the dryer first.... that makes absolutely SURE that nobody uses the dryer when the compressor runs
Old Feb 15, 2007 | 08:03 AM
GaryS's Avatar
GaryS
Well, I have read that this size will work but MIGHT be slightly small for a painting job. That said, I painted my 66 about six years ago with a 25 year old 3.5 hp, 30 gallon Craftsman compressor. Old, noisy, and ran all the time during the big areas. Had to let it catch up at times. I sprayed original lacquer, both color and clear. When it was done I had more compliments than the guys with the professional jobs.
If my really old Craftsman will do it, this one should be adequate.
Gary
Old Feb 15, 2007 | 11:28 AM
stinger12's Avatar
stinger12
Well I will be using a high volume low pressure paint gun when the time comes. Anyone else have any thoughts on whether or not the compressor will be able to pull off a nice paint job...or will I have to go bigger?
Old Feb 15, 2007 | 11:44 AM
noonie's Avatar
noonie
This one previously referred to is much better for your needs and a much better unit.
Originally Posted by King Lear
Yep, here is the one my dad has and it is the same size as the Husky with 1 more HP. His works great with no sweat. TSC is the store.
http://www.mytscstore.com/detail.asp...=45050&x=4&y=2
Old Feb 15, 2007 | 01:06 PM
stinger12's Avatar
stinger12
yeah...but i get a discount at home depot. My friend works there...I also have a $100 give certificate and 20% off. So, that $240 with the 20% discount and gift certificate, plus the discount my friend is going to get me. So I'll only have to pay for half of it in reality...
Old Feb 15, 2007 | 02:38 PM
bobs77vet's Avatar
bobs77vet
that and a sand blast cabinet will be your challenge.....that may not be enough cfm for a HVLP system.....pick out your gun and see what the cfm is that it needs
Old Feb 15, 2007 | 03:03 PM
stinger12's Avatar
stinger12
http://www.autorefinishdevilbiss.com/main.php?p=g&id=1
i'll be using this gun...9-11 cfm it says
