I need 400+ CID sbc Help.....
I have a 1980 el camino, That I'm building for the 1/4 mile and once a month street use. (mpg... HA!) Money is a problem.... I have it, it's there, but have to go cheap and good (BUDGET!!!). With that said, I know what I want to do will not be easy, nor cheap but PLEASE keep in mind I'm a 21 year old, F/T college student, F/T worker, and I'm helping my parents whom have some health issues. The money I have established isn't something I can replenish quickly, so I want to get this build right the first time.
Here's what I have:
1980 el camino roughly 3000lbs (current state)
400 CID (std bore) block, 509 cast.
stock crank, -.010
Heads - 882 drilled for 400 block
intake - torker II, air gap, performer (i have a few intakes.)
Carb - 750 cfm edelbrock
NOS - edelbrock system #70001 I believe
Cam - dont have specs on hand but it's supposedly a 3/4 race cam (already New in motor)
Long tube headers (p/n 85001 dynomax)
Timing gears too
I dont have but thinking about:
Rods - 5.7
Pistons - Forged flat top/.100 dome (10.5-11:1 compression)
I believe that's about it?
I'm wanting to run a 10 second 1/4. I don't care if it's 10.9 or 10 flat
.... I know gearing is the key to a fast time, But I can't gear the car without built motor to tune from. So TQ is king, @ 5252rpms HP becomes top dog.... I'm pretty sure anything close to 650hp will place me in the tens with a full frame G-body. I'm sure you guys have more experience than me. please keep it simple and to the point. IF you've built 377+ please list compnents and part numbers if you can. I havent been to the strip in awhile as a driver.... I want to go back! It'd be like winning my own personal award of achievement.
Note: This is the only motor I have.
A little history about the motor.
It was machined and rebuilt my senior year... so about 4ish years ago. we built it for my dad's truck but that got side lined then I picked uup my el camino for a Grad. present... and was given the engine if I wanted it. since I basically was there from start to finish "heck yeah!" I was leaning towards forged flat-tops with a 6" rod but the machining scared me to a 5.7 rod and it wouldnt need much of a mod. I understand that the 5.565 rods aren't for performance but make great TQ... but the walls take the abuse. So, I figure 5.7 is a good length with maybe a .100 dome top... to help make up for the comp. loss... My dad said tonight "I was hoping I was out of this years ago, but I guess I have to get back into it now"
. I'm hoping someone can lead me to a parts/price/performance list. That'll make getting everything together easier and probably cheaper.
stock crank, -.010
.... I know gearing is the key to a fast time, But I can't gear the car without built motor to tune from. So TQ is king, @ 5252rpms HP becomes top dog.... I'm pretty sure anything close to 650hp will place me in the tens with a full frame G-body.Sounds as though you need a complete rotating assembly to survive your stated goals.
Please state your budget & be realistic.
Realistic goals for those heads fully ported are 300-350HP you are looking at 13's in the 1/4 mile. As stated above "Please state your budget & be realistic." and we can help
Yes I know the cam isnt a 10 second cam, But then again we're not 100% on specs... I'll look for them when I get a chance.
Budget:
There's already $1500 in the machine work.
Odds are it might go back to a shop so probably another $1000-1500
Then a good rotating assembly is what $1100?
Heads (sometime) $2000ish
I know $5000 will build a stout motor, (not including money in it) approx. $3500 is what I have.
If I can only put a bullet proof bottom end together then it's a start! I can always swap heads, and cam. I'm just trying to get pieces lined up, as in Part numbers, and specs. that way I dont put it together and go "ahh heck, now I have to pull it out again, I used the wrong parts" I dont have the time nor money to play that game.
For reference, we wrap up about $15,000 in a 10-second engine. A $3500 to $5000 budget will probably get you in the 13's, and you could even break into the 12's if you get a set of heads.
If you want to run the 10's, get a lighter car and a bigger budget... You're going to need some really good heads and a very stout rotating assembly along with a bullet-proof valvetrain.
How big is you driver...? Huh??
- Block machinework should not be as much as $1K. DO zero-deck the 400 block ... no known thin composite gaskets available for sbc400.
- Build a 420" w/strong bottom end ... all forged ... flattops ... 6" stroker profiled rods ... 3.875" crank ... costs no more to build a forged 420 than a forged 400.
- Run the rest of your stuff until you come up with ~$3K for heads & cam.
But I agree that 80' el camino is not NEAR 4000lbs. In 77' they went to the small G body style on malibus and El Caminos. My friend in high school had an 81, 4 door malibu with a 267 V8. It was his grand mas car and she gave it to him for his 16th b-day. It only had 17k miles on it. This was back in '93. We took it to the track and weighed it and it weighed 3270lbs with a half tank of gas. Thats with ALL factory equipment installed and working, including the baby spare and jack.
I would be suprised if that 80' El Camino weighed over 3300-3400lbs MAX without the driver.
Vet88 definetly needs to re-evalute his goals for his hardware and budget. When I was super young and broke, we would just build decent 350-358" SBs and dumped a ton of nitrous through em. LOL
Lars, I did just that with my 69 El Camino and put it on the scale
cast iron intake and exhaust on a 350, th 400 trans, 1/2 tank of gas and about 2 inches of ice in the bed,,,,, Whats yer guess????? If you said 3500 pounds you would be right. NOW, the 80 is a smaller car. How big is you driver...? Huh??
THE g-bodies hook relatively well with the factory design. trust me I've seen one with a big block lift the front wheels a foot and 1/2 into the air from a dead stop on the street... don't tell me it won't hook. I have a nine inch for it, fabed up and all new internals Everything. Paid $500 for it. So dont give me any "you can't build what you want for that price" I'm telling you I can if you would help me instead of fighting me!
WHAT I WANT IS:
Parts list
Part numbers
power ratings
and what has to be modified.
This is more what I'm looking for, HELPFUL STUFF!
You guys don't get it... I've got so many problems going on around me this car is my release. I HAVE PRO-STREET GUYS with RACE PARTS! Willing to throw in their spare parts cheap to help me I NEED a list to have them go over... No one's helping. my fault for not stating that.
WHAT I WANT IS:
Parts list
Part numbers
power ratings
Thank you.
build the bottom end now, forged everything. do heads when you can. And build as many cubic inches as possible!I cant help with part #'s sorry
