Engine Operating Temp
Old Feb 14, 2007 | 12:18 PM
SoCalErv's Avatar
SoCalErv
Army
Default Engine Operating Temp
I have a sbc 350 that runs constantly at 175 degrees. What is the normal temp range for this engine? I s 175 degrees too cool?
Old Feb 14, 2007 | 01:41 PM
marshrat99's Avatar
marshrat99
How are you measuring the temp? Maybe the guage is slightly off. I normally see temps from 180* to 200* depending on outside temps, how I'm driving, use of A/C, etc.
Old Feb 14, 2007 | 01:47 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
What thermostat are you running? This temp rating generally dictates the minimum temp the engine would operate at.
Old Feb 14, 2007 | 06:41 PM
SoCalErv's Avatar
SoCalErv
Army
Both issue to look at because I do not have the answers.
Old Feb 15, 2007 | 03:35 AM
7T1vette's Avatar
7T1vette
I believe your engine came with a 180 degree thermostat. Either your gage or the thermostat (or both) are a few degrees off.....incidental. Your temp is just what GM wanted in '69.
Old Feb 15, 2007 | 03:53 AM
a smith's Avatar
a smith
If that is a correct temp reading that is probably a perfect running temp. Vegas
To Engine Operating Temp
