BB Lifter Problem - Rebuild or Just Fix
Old Feb 14, 2007 | 05:41 PM
CCrane65's Avatar
CCrane65
Default BB Lifter Problem - Rebuild or Just Fix
Problem found. See my 02/23 post.
My engine started making a clattering noise and running poorly last week. Like one of the cylinders was not firing.
Then it clears up for a while but it always comes back. After listening to it carefully, I and my friends have determined that it is likely a hydraulic lifter that is not always pumping up and therefore not always opening the valve. Sounds like it is the number 2 cylinder.
The car has at least 95K miles on it so the question is, do I just replace the lifters or do I rebuild the engine completely?
I don't know for sure how many miles are on it because the odometer stopped at 95620 before I acquired it.
If I just fix it howlikely is it that something else inside will go belly up?
If I rebuild it, I would like to up the horsepower to 1970 specs if it doesn't cost much more than rebuilding it to original 1972 specs.
I don't want to have to switch to premium gas if I can avoid it.
Any suggestions/help appreciated.
cc
Old Feb 14, 2007 | 05:50 PM
Durango_Boy's Avatar
Durango_Boy
It's likely just a collapsing lifter as you suspect. It's an easy operation to change lifters. A full new set is a safe idea in case any more are close to failing.
Maybe pull the oil pan, inspect the bearings and cylinder bores.
If you feel there are other issue besides the lifters, then perhaps a rebuild is a good idea as well.
Old Feb 14, 2007 | 07:06 PM
zwede's Avatar
zwede
Before you pull it apart, add a pint of marvel mystery oil to the crank case. It fixed a badly stuck lifter on a car I used to have and has done the same trick for several forum members.
Old Feb 14, 2007 | 07:18 PM
shafrs3's Avatar
shafrs3
First pull the suspected valve cover and check to see if the adjustment nut hasn't backed off. That's an cheap and easy fix if it turns out to be the cause.
Old Feb 14, 2007 | 08:17 PM
CCrane65's Avatar
CCrane65
If the adjustment nut has backed off, wouldn't it do it all the time? This acts more like a sticking lifter.
cc
Old Feb 14, 2007 | 08:18 PM
CCrane65's Avatar
CCrane65
For a couple of bucks and change, that's worth a try.
I'll let you know how it goes.
cc
Old Feb 14, 2007 | 11:02 PM
TimAT's Avatar
TimAT
I'm gonna' step out on what some may consider a limb here.
If a lifter is bad, and you put a new lifter on a used cam, you may end with a cam that's flat. A new cam and lifter(s) establishes a wear pattern. A new lifter will have a new surface- no wear patten. As it wears in, it will usually eat the surface off an old cam. And now it's a flat cam.
I'd suggest a careful inspection of the valvetrain components. Spring, rocker, pushrod, and then pull that lifter and look at it.
Old Feb 15, 2007 | 09:16 AM
sly vette's Avatar
sly vette
At 95K miles, I would say a freshen up of the entire motor is in order!
Old Feb 15, 2007 | 09:46 AM
juiceman03070's Avatar
juiceman03070
St. Jude Donor '08
Might be just a gummed up oil feed in pushrod or carbon build up.....
Old Feb 15, 2007 | 10:05 AM
Durango_Boy
Great point, and it makes me wonder just how complex that wear pattern would be. I mean, don't all non-roller lifters spin during operation?
Old Feb 15, 2007 | 10:31 AM
TimAT's Avatar
TimAT
Yep. They all spin. Hydraulic or solid, they spin. And that's where the wear pattern comes in. The parts seat together and (hopefully) become happy. When you change a lifter on a used cam, they need to develop a new wear pattern. And a good chance that the surface of the old cam won't have enough of whatever the manufacturer did originally to stand up to a new wear pattern. And you get a flat lobe.
I've heard of guys swapping lifters and running for years. But IMHO, the odds are against it. If I rebuild an engine and use the same cam/lifters, I have a 2x4 I drilled 1" holes in and numbered to be sure I put the same lifter back in the same place.
Old Feb 15, 2007 | 11:18 AM
CCrane65's Avatar
CCrane65
Well, I poured the MM Oil in this morning and ran the engine for about 15 minutes. It seems to have taken care of the lifter noise but I won't know that for sure until I can drive it.
It is runnig a bit rough however but at 15 degrees aren't we all?
One thing's for sure, nothing much else is going to happen until we get some warm weather around here.
Old Feb 23, 2007 | 09:50 PM
CCrane65's Avatar
CCrane65
Problem found. Turns out it was not a bad lifter. It was a bad rocker arm but you gotta see this thing.
It looks like it was split nearly in half. I have no idea what could cause that and not cause any other problems. The valve is fine and there is no smoke coming from the tailpipe so I assume the piston doesn't have any holes in it.
This was on an exhaust valve so there was obviously a lot of pressure building up in the cylinder because the rocker wasn't even touching the valve.
Once I replaced the rocker the car started running great. By the way, the rocker retaining nut wasn't loose or anything so it wasn't caused by that.
So, any ideas what could have caused this and why nothing else got broken?
See it here:
Yeah I know, it's pretty fuzzy.
cc
Old Feb 23, 2007 | 10:00 PM
sly vette's Avatar
sly vette
Fatigue or not enough lube???
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I had "something" stuck in my old GMC pickup one time. Changed the oil and substituted a quart of Marvel. (My Dad loved that stuff) I drove it about 20 miles....you could feel it immediately when the lifter unstuck. I drove that oil for about 1000 miles, than went back with plain ole Castrol. Been fine ever since....12 years ago.
Good Luck !
Nevermind......I just saw your picture of the rocker....Marvel is good stuff, but it won't fix that!
Old Feb 23, 2007 | 11:49 PM
rihwoods's Avatar
rihwoods
Very possible..I had that problem with a stock 73 truck 454 once..had to go to aftermarket rockers...seems residual stress was the issue with some "stamped" GM rockers from their grinding process..
Edit..
I might add that once a push rod poked thru the rocker..but some broke in half like an egg...just like the pic above...GM buried their heads in the sand...
Rich
Old Feb 24, 2007 | 06:32 AM
TimAT's Avatar
TimAT
The rocker giving up is not uncommon at all. GM has rockers that have grooved ***** to hold oil better. Move a used rocker from an intake to this exhaust spot and put the new one on an intake. Intakes run cooler per GM.
Glad you found it and it's not a big deal.
To BB Lifter Problem - Rebuild or Just Fix
Old Feb 24, 2007 | 11:05 AM
sly vette's Avatar
sly vette
Is that also why some guys are running 1.6 rollers on the exhaust rockers??? Or is it only for the increased lift???
Old Feb 24, 2007 | 07:41 PM
LemansBlue68's Avatar
LemansBlue68
I'd check to make sure that the oil hole in the pushrod is not clogged or that the lifter is even supplying any oil to the pushrod. I had a Cutlass years ago that had a similar issue with the rocker arm wearing severely. The oil hole in the pushrod was completely blocked shut.
Old Feb 24, 2007 | 09:44 PM
CCrane65's Avatar
CCrane65
You know, if something in the valvetrain is going to give, the rocker is a pretty good choice. Potentially saves more extensive repairs. That is, if it will break when needed. Probably not though. GM engineering wasn't that good.
cc
