lokar cable install question
Old Feb 24, 2007 | 10:19 AM
blctalon's Avatar
blctalon
Default lokar cable install question
Those of you that have installed a lokar throttle cable, what did you do at the firewall as far as fastening the cable in the stock hole?
Old Feb 24, 2007 | 02:14 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I used 1" washers with small diameter holes on both sides of the firewall to accommodate the size of the Lokar threaded bushing.
Old Feb 24, 2007 | 02:43 PM
blctalon's Avatar
blctalon
That's a good simple idea, thanks.
Old Feb 25, 2007 | 09:35 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Fender washer as they are called. Use dremel tool to cut outer shield of cable and cable itself. These things are great!!!!!!!!
tt
To lokar cable install question
