Need a good water pump. Recommendations please...
Old Feb 27, 2007 | 08:23 PM
noonie's Avatar
noonie
Originally Posted by dragonracer
Uh-oh looks like i got in the middle of a spat, sorry!
Isn't that what a lot of people were whining about lately?
You are supposed to straighten it out, so no one is misinformed.
Old Feb 27, 2007 | 08:25 PM
7T1vette's Avatar
7T1vette
Not a problem dragonracer. I'm just trying to clear up some mis-conceptions about cooling systems so that everyone understands how a dynamic heat/cool system operates. The reason I got involved at all is that many folks think "more is better" when you are working on just one piece of a closed multi-part system. You have to consider the interactions of all the pieces in the system, as well. For a good cooling system, the heat exchanger AND the pump AND the fan all have to do their respective jobs. If one of the pieces in incapable of doing its job, the others can't make up for it.
Old Feb 27, 2007 | 10:30 PM
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
I am goning to have to side up with the fellow from the desert...Being a Desert American myself.. By the time your are 16 years old, you have a good idea on how to keep a engine running as cool as possible. All the components need to be in a balance...It is just like life, if it is out of balance in one spot....then everything seems outawack....and it is hard to put you finger on what is wrong.
Back where I come from when the Summer Time rolls around ,and the Roads and Streets start to melt, and your tires get hot, and fail because they can not cool down.... I have not tried BIGGER TIRES..... only because the Semi-Trucks, seem to have a even worse time of keeping the rubber on the rims.....
Old Feb 27, 2007 | 10:35 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Ahhh i might be denser than most , but I believe its the more airflow you push through a heat exchanger the more cooling you get. Could
be wrong, my wife tells me I am all the time.
That is true too. I also agree with noonie that airflow is the largest factor and limiter in these cars. That wasn't the point of the discusion here though. The question was regarding a water pump and coolant flow.
I also agree that coolant flow will not compensate for other deficiencies in your system (I believe I said that in the first post).
I will counter with a thermodynamic observation. Why does increased air flow increase cooling but increased coolant flow decrease cooling? The answer is that it doesn't.
Old Feb 27, 2007 | 10:43 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by 7T1vette
Gettin' a little picky, I think. We can debate this all you want, but the faster you put fluid through a heat-exchanger, the less cooling you get. And if you push it through TOO FAST, you get darned little and the whole system overheats. Soooo....if your radiator/fan system is INADEQUATE, it is irrelavant as to what pump you are using....[Oh, just to be perfectly clear...unless it doesn't pump at all.]
I have seen heat exchanger efficiencies improved with lower flow rates. We use computers and variable frquency drives on pumps to maximize heat exchange.
Old Feb 27, 2007 | 11:30 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Too much flow is less efficient at cooling. I know this doesn't sound correct but the water needs to be in the radiator long enough to cool off before going back into the engine. To high of flow can be detrimental to cooling. A stock water pump is fine for most applications.
Old Feb 27, 2007 | 11:35 PM
7T1vette's Avatar
7T1vette
Thanks for the support on this issue. I don't care to be "right", I'd just like the Forum folks to gain a little understanding of the "give" and "take" of a system. You have helped to better describe what I wasn't able to get across. Thanks.
