Re-use Head Gasket??
Old Mar 1, 2007 | 10:54 AM
King Lear's Avatar
King Lear
Veteran
Originally Posted by Jud Chapin
Keep in mind that if they leak, you'll be tearing the engine down again. To me, it's just not worth the risk.
Old Mar 1, 2007 | 03:07 PM
Ironcross's Avatar
Ironcross
Originally Posted by 427Hotrod
If they are decent composition style you'll be OK. If they are steel shim..it might be iffy.
Done it many times with the std Fel Pro blues. Cometic markets theirs as being able to reuse,,,and then of course copper ones are re-used all the time.
JIM
Old Mar 1, 2007 | 03:38 PM
Superstock's Avatar
Superstock
Default 427 Hotrod
Old Mar 1, 2007 | 03:46 PM
Edzred72's Avatar
Edzred72
Originally Posted by GasketDude
In your case you can reuse! We did plenty of static work on samples and then placed on dyno engines with no issues. Most situations required replacing but again, in your case, it will be fine. Theres a solid core wire under the S/S armor, there will be no problems with combustion seal leakage. Next the coolant sealing beads and gasket body, in good shape, they will be ok to reuse.
With those fasteners you'd probably wear out the threaded holes in the block before issues with stretch. As long as you follow torque specs.
Motor on!
Later.
Good to know for next time.....Thank you for your reply
Eddie
