AFR Eliminator head problem with Hooker sidepipes
Old Mar 1, 2007 | 07:54 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Are these the new Eliminator heads ?, What is the flow at .700" ?
Old Mar 1, 2007 | 08:09 PM
King Lear's Avatar
King Lear
Veteran
The 210cc claim 301/224 @ .700 on the race ready ones, 312/236 @.700 on the competition ported ones.
The 227cc claim 315/236 @ .700 on the race ready ones, 327/243 @.700 on the competition ported ones.
Old Mar 1, 2007 | 08:32 PM
CorvetteDave01's Avatar
CorvetteDave01
Thanks for the info man. I am worried about that exact issue really. The main thing is the cost and I keep justifying the flow numbers on the 210s being high as the reason I don't need to spend the extra 600-700 for the shaft rocker setup I will need with the 227s. Not even sure I can change the order yet anyway...thinking about checking with the speedshop tomorrow on this though. I know I am driving this guy at the speedshop nuts at this point.
The other thing is how fast I can run the quarter in a 3500 lb car with this motor AND my basically stock, but new drive train with the tremec TKO trany and the dragvette girdle. I was figuring I was at the limit at 600 hp, but would eventually break something (and then have a good excuse to look at a Tom's setup. I do have heavy offset trailing arms, cryogenically treated axles, new heavy half shafts and driveshaft as well.
Old Mar 1, 2007 | 09:07 PM
MotorHead's Avatar
MotorHead
These are the flow numbers for the new Eliminator 210's ?
What cam are you running ?
Old Mar 1, 2007 | 10:02 PM
CorvetteDave01
I'm looking at a couple of options in custom grind setups. Hydraulic roller cams. These numbers are adjusted for the 1.6 rockers.
1. 248/256 dur @ .050, 640/640 lift, 112 deg LS
or
2. 234/240 dur 622/624 lift, 112 LS
What do you think?
Old Mar 1, 2007 | 11:02 PM
MotorHead's Avatar
MotorHead
I would go with the bigger duration cam, not sure about how much vacuum you will have though, bigger cubes will help.
I am slowly putting together parts for a 600HP 427ci small block myself. To get the HP I think I have to use a solid roller, I am however seriously considering a Comp Cams hydraulic roller either the 286HR or the 305HR, the 305HR is only 244 degs duration and you can get .640" lift with 1.6 rockers.
Old Mar 1, 2007 | 11:13 PM
King Lear's Avatar
King Lear
Veteran
or
What do you think?
I would base it on what ever CR you are going to have and what gears you are running. Which ever cam best matches all the components would be the best. I wouldn't worry about lift as much as I would how many RPM's you really want to turn with it. The longer duration is the more compression your going to have to come up with. I used to work with a guy that put in a huge duration cam and a .600 lift cam around there anyway. I checked the cams specs for him, it was supposed to have a minimum of 10.5:1 CR operating range. He had it in his stock 8.5 CR camaro and wondered why it sounded and ran like sh$t. The mechanic that did that for him should have been ashamed of himself.
Old Mar 1, 2007 | 11:18 PM
CorvetteDave01
Probably shouldnt have started the other camshaft thread. I have the TKO500, think its a 3.27 first gear? This with a 3.08 differential and a 295 50 15" wheel, think it's around 4.10?
I drive it 1-2 times/week, but mainly want it for bracket racing, but all my car specs on the camshaft thread I just started, but I really wanted to push the drivetrain to it's limit and if it breaks, buy a Tom's...
Old Mar 1, 2007 | 11:25 PM
King Lear's Avatar
King Lear
Veteran
I would go with the bigger cam if you plan to get rid of the 3.08's eventually. I would go bigger and get rid of the gears, ring and pinions are cheaper then rollers!
Old Mar 1, 2007 | 11:39 PM
King Lear's Avatar
King Lear
Veteran
just replied on your cam post!
