Oil cooler
Dep
I smell a poll. General right?
you may say it is for the environment and mother earth, but i say we are just giving back what we took in the first place
Dep
Dep
ESU
Some oil facts:
Viscosity is a measure of the "flowability" of an oil. More specifically, it is the property of an oil to develop and maintain a certain amount of shearing stress dependent on flow, and then to offer continued resistance to flow. Thicker oils generally have a higher viscosity, and thinner oils a lower viscosity. This is the most important property for an engine. An oil with too low a viscosity can shear and lose film strength at high temperatures. An oil with too high a viscosity may not pump to the proper parts at low temperatures and the film may tear at high rpm.
Multi viscosity oils are one of the great improvements in oils, but they should be chosen wisely. Always use a multi grade with the narrowest span of viscosity that is appropriate for the temperatures you are going to encounter. In the winter base your decision on the lowest temperature you will encounter, in the summer, the highest temperature you expect. The polymers can shear and burn forming deposits that can cause ring sticking and other problems. 10W-40 and 5W-30 require a lot of polymers (synthetics excluded) to achieve that range. This has caused problems in diesel engines, but fewer polymers are better for all engines. The wide viscosity range oils, in general, are more prone to viscosity and thermal breakdown due to the high polymer content. It is the oil that lubricates, not the additives. Oils that can do their job with the fewest additives are the best.
Flash point is the temperature at which an oil gives off vapors that can be ignited with a flame held over the oil. The lower the flash point the greater tendency for the oil to suffer vaporization loss at high temperatures and to burn off on hot cylinder walls and pistons. The flash point can be an indicator of the quality of the base stock used. The higher the flash point the better. 400 F is the minimum to prevent possible high consumption.
Go here to see the specs for different oil flashpoints and viscosities.
http://www.repairfaq.org/filipg/AUTO/F_oil_facts.html
Dep
cars or pickups never had an engine fail yet while living here.
I will admit I don't have any 775 hp, 358 cube engine turning
8900 rpm for two hours at the daytona 500. if your going with an
engine oil cooler on a street car may as well put a cooler on
your manual trans and one on the rearend, that way with a
condom on everything you will be well protected. have fun
if you just want an oil cooler.
Thanks to all for your comments!
Not just rhetorical...does it actually hurt anything?
I have already bought the donut. I already have the cooler. I would really hate to install everything, get to driving, and find the oil temps a little high for my taste. Then, it's back under the car where it's now harder to work and install when it could have been done from the start.
It is my money, and I'm not saying anyone is wrong or that I'm right...I'm just curious if there really are any dangers to running an oil cooler aside from extending the time it takes to get the oil to operating temp.
I don't think the oil cooler is needed here but if it makes you feel better fine. A better oil might be a better way to spend you money though, somthing with a good heat dispersante (I am not talking about mobil 1 or others that spend more $$ on ads than R&D)
1st place oil goes after leaving the oil pump is to the filter, then to the oil galleys within the block.
Most add-on type oil coolers intecept the flow of oil after it leaves the filter and before it goes to the oil galleys.
The oil pressure at the galleys is lower coming from an add-on cooler than if no cooler were installed unless the oil filter bypass valve is opening.
Installing one of these add-on type oil coolers could cause some or all the oil to bypass the filter and cooler by opening or partially opening the bypass valve.
If this is going on, you'll never see the pressure drop on your oil gauge and you'll be running unfiltered oil through the engine.
