I was wondering in you could send the oil through the radiator to cool. Anotherwords, where the old tras cooler would be connected. I would do this instead of purchasing a standard oil cooler and mounting it to the front underneath.
Pros..cons...can it even be done or maybe it is just a stupid question?
A con would be that it'll just add more heat that the radiator has to deal with. You'd be a lot better off with an external cooler, mounted at one of the corners with it's own fan and thermostat. I'm gonna end up doing it that was too.
That is what I thought, but you guys confirmed it.
I have an aluminum radiator and I ask Dewitts the same question. The radiator (tranny) side pan does not have the size volume for engine oil.
The thermal line adapter in place of the oil filter is our best option
So what's with all the oil cooler questions? Is everyone's oil REALLY running that hot? Or is this just another fad? Personally, I'd rather spend the money on fuzzy dice.
Dep
Good question... Here is my 2 cents on the topic. I live in Texas where it will be over 100 deg for weeks at a time. Driving in this type of weather it will be difficult to keep her running cool (I think). I have a Griffin radiator and a newly installed dual spal setup.
However, if I get caught in heavy traffic on the highway or side roads, which can be brutal, I do not want this car to over heat no questions asked period.
Also, if I am at the track this will assist in keeping down the temps while doing passes in 100deg weather.
Well I still wonder why. I mean your cars are not the FIRST hot rods (excuse pun) to be used in Texas or other locations where it's hot. Heck, I have no doubt there are much WILDER modded cars that were used with no problem in those states. I know DB doesn't carry a spare tire. Seems to me the chances of getting a flat are much higher than oil getting so hot it loses it's protective ability. Unless your engine is getting ABOVE 250-270 degrees for an extended period of time, I think an oil cooler is a solution looking for a problem in most cases.
Of course, if you're going for "coolness factor", a completely different term, then it's a different story
Not to get off the subject but where did you get your hood. That is exactly the look I want. How much extra clearance did it give you over the stock hood? That 427 style hood looks sharp!
Rich
Dep
I agree with your first statement,but I think you missing the point. Loosing the oils protective ability is not my main concern. Reducing the oils temp helps keep the engine cooler than it normally would. Also installing one of these has no loss on the elec system or engine. I have one fan running on a temp switch and the other fan is manual (less elec power draw). The oil cooler opens when temps hit 190 and closes at 170 again with no load on the elec system. Hopefully, the second fan will never be required with the use of the oil cooler.
Rich
Thanks for the complement. I bought it from Ecklers and I was lucky becasue it bolted right on with 0 mods. I would not expect that normally, but good luck.
I was trying to make it different while keeping the old school look, I think I got it.
Thanks, you definitely got it, I was actually thinking of finding an old 427 hood and cutting it and fiberglassing it in the 72 hood some how. Now that I saw yours I am going to try ecklers, it looks great!
I hope that explains it a little better.
I doubt that cooler oil is going to make that much difference in engine temps or engine performance. If it was an air-cooled engine like on a Harley, I could definitely see the benefit of an oil cooler. I still think you guys are throwing money away. But it's your money, so have fun
