Will an oil cooler really lower engine temp.
Old Mar 6, 2007 | 11:09 AM
  #141
David Ey's Avatar
David Ey
Originally Posted by DJ Dep
Norval????? Where in the world does Mr. Bolt-in come into play???? ..........
HEY, Watch It Buddy!
Old Mar 6, 2007 | 11:12 AM
  #142
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Sorry Norval #2...didn't realize there were two Norvals on the forum.
And Norval #1 and I go way back...so watch it yourself
Dep
Old Mar 6, 2007 | 12:12 PM
  #143
David Ey's Avatar
David Ey
I'm not sure I'm a likein you.
Old Mar 6, 2007 | 12:22 PM
  #144
genuine1980's Avatar
genuine1980
Originally Posted by Durango_boy
External oil coolers do in fact lower oil temp.
My point was to start a discussion about an external oil cooler and if it had effects on engine temp, not oil temp. So far, it seems that they are not NEEDED but that they do affect engine temp. It seems that if you lower the oil temp, and that's the only change you made, the engine temp will follow.
I said it once and I'll say it again...
On a 'normal' circumstance an oil cooler will not lower engine temp. Your normal cooling system and thermostat does that.
If you are running a 180* thermostat and your car runs @ 180* degrees before you 'only' install an oil cooler, the engine temp will not lower following the oil cooler install if the oil cooler is the only change you made. The 180* thermostat wont let your engine run under 180*.
Again this is under normal circumstances.
However if you consider the extreme circumstance...
If you're running a 160* thermostat or even no thermostat and your engine runs at 170* before installing an oil cooler, you might see 'some' additional cooling after having only installed an oil cooler.
OR if your cooling system has a problem where your car run 190* with a 180* thermostat, you might see a change.
Yes oil plays a roll in keeping the engine cool, while it lubrcates and takes heat away from the moving metal parts, but your cooling system keeps engine cool thus cooling the oil and everything else. Change the temp in the cooling system via better radiator or different thermostat and the engine temp and oil temp will follow... not the other way around.
My .02
Old Mar 7, 2007 | 02:11 PM
  #145
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
noonie: You might get a little more legitimacy and credence to your posts if you posted some info about yourself. Otherwise...this guy comes to mind--------->
Dep
Maybe if you'd been around during the past six months, you'd know that noonie has demonstrated that he knows what he's talking about.
Old Mar 7, 2007 | 02:17 PM
  #146
Big2Bird's Avatar
Big2Bird
Sorry Dep. Noonie is sharp as a tack. Would like to see his profile posted though.
Old Mar 7, 2007 | 02:24 PM
  #147
Little Mouse's Avatar
Little Mouse
Let's not leave out anything..
""In many ways, the LS7 is a racing engine in a street car," said Dave Muscaro, assistant chief engineer of small-block V-8 for passenger cars."
Anyone on here running a dry sump system on the street? Pretty rare I'd say.
Here's DETAILS on wet sump vs dry sump:
http://www.moroso.com/articles/artic...utOilPans.html
Note: "Other advantages of a dry sump system include increased oil capacity, more consistent oil pressure, the ability to easily add remote coolers, and adjustable oil pressure. And because the pan doesn’t store oil, it can be relatively shallow in depth to allow lower engine placement for improved weight distribution and handling."
So what's next...you wanna go the whole route and install a DRY SUMP SYSTEM? This oil cooler idea is getting more complex and EXPENSIVE the more you guys talk about it.
Dep
Don't forget the titanium valves that chevy is using to get the hydraulic cam power range extended to 7000 rpm, last time I
looked titanium valves are $100.00 apiece X 16.
Old Mar 7, 2007 | 03:48 PM
  #148
DJ Dep's Avatar
DJ Dep
I'd still like to know some details about who I am talking to. The past 6 months most of the REALLY knowledgeable people have LEFT. All I've seen so far from Noonie is the "amazing" ability to copy and paste stuff and to question everthing I post, but supply no legitimate alternative replys. I'm not impressed.
Dep
