Will an oil cooler really lower engine temp.
Old Mar 3, 2007 | 10:13 AM
  #101
David Ey's Avatar
David Ey
Well, after reading all this, my conclusion is the oil cooler is not necessary but I'm going to bubba me up an oil pre-pump to get that stuff pressurized before the engine turns over. That way I should get about 8.34 million miles out of a motor.
Old Mar 3, 2007 | 10:19 AM
  #102
redvetracr's Avatar
redvetracr
Originally Posted by turtlevette
this is starting to get muddled.
turtle, remember where you are!!
Old Mar 3, 2007 | 11:04 AM
  #103
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Originally Posted by noonie
Having had BMW bikes in years past, this seemed interesting so I checked, and the answer surprised me.
That series of BMW bikes is oil/air cooled with the head being totaly enclosed and cooled by oil. The cylinders still have fins for air cooling. The crankcase etc is also conventionally cooled. Quite an inovative design.
BMW production cars (water cooled) have had external oil coolers for at least the last 20 years.
Certain Porsche models which are air cooled, relyed heavily on an external cooler for overall cooling with the most important factor being that their design oil temperature was approx 185°.
I think we can all agree that these makers are a lot less price conscious than GM, so cost should not be a consideration.
So not trying to reinvent the wheel here, I certainly would think that the little cost of properly adding and having an oil cooler would certainly be better than not having one. These guys have an excellent track record and their conclusions are good enough for me.
BTW, here is another interesting tidbit I ran accross.
Porsche 2006 Cayenne Turbo S is the world's most powerful SUV, with 521 HP is also the world's most powerful production V8, and more powerful than almost all other V10s and V12s, too.
I don't think it's wise to base your decision for or against an oil cooler on German designs. Those folks in Germany have been "overbuilding" vehicles for a very long time. But they also have VERY different driving situations (Autobahn), as someone else noted. Most American cars driven IN America DON'T have oil coolers. That pretty much negates the few from Germany that do.
Dep
Old Mar 3, 2007 | 11:15 AM
  #104
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Dep
European and asian cars have great big oil cooled heat generators called turbochargers on them.
Besides oil coolers are there to cool the oil, which has more to do with keeping oil in their prime lubricating heat range than cooling the engine, at least in my mind.
Old Mar 3, 2007 | 12:22 PM
  #105
noonie's Avatar
noonie
I agree, if you consider increased dependability and much greater longevity "overbuilding"
For many years now, German cars have been intended for a world market, some are even manufctured here in America. If only American cars were so sought after world wide.
Japan has consistantly over the past few decades taught us about American cars in America and just recently surpassed GM for marketshare. It might be time for us to fall back and punt. Maybe with a little more forward thinking, we can catch up again.
As I mentioned earlier and as Guru_4_hire stated, it's about the oil.
I prefer to play it safe have a cooler.
Old Mar 3, 2007 | 12:53 PM
  #106
Guru_4_hire
Cruise-In V Veteran
An oil cooler without a thermostat is just as bad.
Old Mar 3, 2007 | 12:59 PM
  #107
DJ Dep's Avatar
DJ Dep
Well if you want to "play it safe" might as well have airbags installed all around and install 4 oil filters and never drive on days where the outside ambient temp doesn't go above 95 degrees and get puncture-proof tires and bullet-proof glass and a 12 point roll bar, etc etc etc. Where does it end????
Do you even KNOW when oil temps actually become a worry? Or are you simply a paranoid gizmo addict??
Dep
Old Mar 3, 2007 | 01:17 PM
  #108
Guru_4_hire
Cruise-In V Veteran
Depends on the oil.
I am planning on using a pair of turbos, and probably mobil 1. I will probably email Mobil and find out about the operating range, and install an oil cooler and thermostat. But with 2 heat generators for the oil, I think its gonna be required.
Especially with the amount of money, time, and love I am putting into this.
I like the idea of the oil accumulator too.
Old Mar 3, 2007 | 01:37 PM
  #109
Twin_Turbo's Avatar
Twin_Turbo
for a turbocharged engine an oil cooler is a very good idea (granted that you use a thermostat) since the turbos will put a significant amount of heat into the oil.
i have both an oil accumulator for turbo oiling after shut down and a big oil cooler (w/ thermostat AND a manual bypass valve)
Old Mar 3, 2007 | 02:34 PM
  #110
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
bottom line.
show N' shine = no cooler needed
run hard or road race = do it.
Old Mar 3, 2007 | 02:39 PM
  #111
yellow 72's Avatar
yellow 72
St. Jude Donor '09
bottom line.
Some of us can do both
Old Mar 3, 2007 | 03:04 PM
  #112
Big2Bird's Avatar
Big2Bird
Then you need a polished cooler.
Old Mar 4, 2007 | 02:32 AM
  #113
noonie's Avatar
noonie
Dep
It starts and ends with an oil cooler,
Just like the topic of this post says.
BTW It was 89° F here today and it is winter.
Old Mar 4, 2007 | 12:48 PM
  #114
spikezz4's Avatar
spikezz4
Default Oil Cooler
The oil cooler on the L98 C4's had an adaptor on the oil filter mount that routed hot oil to the radiator for cooling. Project Shark Attack had one installed and the engine temps never were anything other than 210 degrees on the water temp gauge. The cooler reduces oil temps about 20 degrees or so, but the combination helps to stabilize the engine temp reducing the up and down temperature spikes, especially with A/C. An engine can live without an oil cooler, but everything in total helps, even if just a little bit, towards longevity.
Spike
Old Mar 4, 2007 | 05:17 PM
  #115
DJ Dep's Avatar
DJ Dep
Spike
That's nice....but that device is osoloete now ACCODRDING TO GM. I already posted that GM did away with oil coolers and went with synthetic oil. Works just as good.
Dep
Old Mar 4, 2007 | 05:53 PM
  #116
BerniesVette's Avatar
BerniesVette
GM is still putting oil coolers on several vehicles.
Bernie
Old Mar 4, 2007 | 06:32 PM
  #117
DJ Dep's Avatar
DJ Dep
Bernie
Not Corvettes
Dep
To Will an oil cooler really lower engine temp.
Old Mar 4, 2007 | 06:56 PM
  #118
noonie's Avatar
noonie
GM does install an oil cooler on a Corvette
The LS7 has a dry-sump oiling system designed to keep the engine properly lubricated during the high cornering loads the Corvette Z06 is capable of producing. An engine compartment-mounted 8-quart reservoir delivers oil to the engine oil pump under the demanding conditions of cornering loads in excess of 1 g.
Oil circulates through the engine and down to the oil pan, where it is sent back to the reservoir via a scavenge pump. The large-capacity reservoir, combined with a high-efficiency air-to-oil cooler, provides necessary engine oil cooling under the demands of the engine's power output. With the dry-sump system, oil is added to the engine via the reservoir tank - which includes the oil level dipstick.
http://www.corvettemuseum.com/specs/2006/LS7.shtml
Fairly reliable site.
Old Mar 4, 2007 | 07:55 PM
  #119
Big2Bird's Avatar
Big2Bird
Can't wait to hear this next one.
Old Mar 4, 2007 | 08:14 PM
  #120
63mako's Avatar
63mako
St. Jude Donor '08-'09
Dep
Most of us "overbuild" our cars. This IS tech and performance! Some of us also drive our cars as they were meant to be driven afer we "overbuild" them. Most "American cars driven in America" don't run the quarter in under 11 seconds, put 500 plus HP to the ground or corner in excess of 1 G either. That C4 adapter with an oil cooler mounted in front of the core support might not be such a bad idea for some of us for a minimal cost. If you got $10000 in your motor and drive it to it's capabilities a little insurance wouldn't hurt. An inline shutoff valve for race or street use sounds interesting too!
