Removing 74 BB heads ??
Old Mar 2, 2007 | 02:47 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Removing 74 BB heads ??
I know about INSTALLING heads....but....is there a correct bolt sequence or technique to follow when REMOVING heads that have been installed for 33 years ??
Thanks....I'd rather ask a dumb question than wish I had !
Old Mar 2, 2007 | 03:14 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
No real sequence needed but I still tend to go from the center bolts out in a clock pattern. Just a habbit I guess. But be aware those heads are VERY HEAVY especially when you are bent over a fender.
Old Mar 2, 2007 | 03:17 PM
Bob3700's Avatar
Bob3700
You'll gain a new appreciation for aluminum BB heads once you lift that "Detroit Wonder Metal".
The intake isn't a whole lot better.
Now just think, If I had AL heads, intake, water pump, how much weight could be removed off that front axle.
Don't they make AL blocks too!!! Ya, Ya, that's it. Aluminum block it is.
Just my fantasy.
Bob
Old Mar 2, 2007 | 03:27 PM
fotyfobravo
Thanks for the info...
Would you believe this all started as "just a good engine clean up!"
Old Mar 2, 2007 | 03:33 PM
kdf1986's Avatar
kdf1986
I know that feeling. What ever it is that I am doing, the 30 minute job turns into a 3 week project.
Are you replacing the heads with an aftermarket version? What about rockers, valve springs, etc.
kdf
Old Mar 2, 2007 | 03:39 PM
fotyfobravo
kdf
No, not this one...I will go back with all the original components with a new comp XE268H cam - lifters - springs. Considering this car still has the original water pump, carb and fuel pump ... this is more of a restoration than a remod.
Old Mar 2, 2007 | 05:00 PM
7T1vette's Avatar
7T1vette
Well, at least you won't have to consider changing springs!!
Old Mar 2, 2007 | 05:27 PM
jackson's Avatar
jackson
The intake isn't a whole lot better.Bob
Eatcherwheaties!
Old Mar 2, 2007 | 06:06 PM
mayberg's Avatar
mayberg
What are your thoughts on original exhaust manifolds vs. headers?
Are you considering any head work - like a pocket port? Valve job/seals?
And, please keep us posted on your engine work.
Old Mar 2, 2007 | 07:34 PM
Steve's74's Avatar
Steve's74
Bob
Yup, that 80 lbs. of cast iron generally tends to pick your feet up off the floor when you try to lift it up while leaning over the fenders. Be very careful on the passenger side if you have A/C. Tolerances are mighty tight there. I managed to punch a hole through the blower housing when I broke the head loose. All that weight tends to go where it wants to.
Steve
Old Mar 2, 2007 | 08:27 PM
Gage's Avatar
Gage
on my 71, the heads wouldn't come off. I had to run a chain through them and use a cherry picker to "break" them loose. Its like they are glued to the block.
To Removing 74 BB heads ??
