changing headlight on '79?
Old Mar 3, 2007 | 02:51 PM
moravecb's Avatar
moravecb
5th Gear
Default changing headlight on '79?
Do I change the headlights with them up or down? then How do I get the old lights out?
I know this is a stupid question but I can't find the answer anywhere. Not even in my Shop Manual. I just finished replacing the Starter because of Heat Soak, I figured I'd try one more project today.
Old Mar 3, 2007 | 03:47 PM
Glassbowtie77's Avatar
Glassbowtie77
The headlights get changed with them in the up position. Use a Philips Head screwdriver to remove the 4 screws from the headlight bezel, then remove the bezel. Next remove the 3 screws that hold the chrome ring around the headlamp and remove the chrome ring. Lift the bulb out and unplug the socket from the back of it. To assemble just reverse the disassembly procedure. There are 3 headlight aiming screws attached to the headlight bucket, be sure not to remove or turn these screws or the will put your headlight aim out of adjustment.
Old Mar 3, 2007 | 03:56 PM
Duke94's Avatar
Duke94
On this Forum, there are no stupid questions.
Old Mar 3, 2007 | 03:57 PM
Glassbowtie77
Welcome aboard.
Old Jan 16, 2013 | 07:00 PM
BretMorris's Avatar
BretMorris
Hi,
I need to replace my bulbs as I have a C3 in Australia so need to get the high beam to point the right of the road. Can someone tell me the specification for the bulb so I can get a suitable Australian replacement?
Bret
To changing headlight on '79?
