Seat Removal Question
Old Mar 3, 2007 | 08:17 PM
VetteramI's Avatar
VetteramI
St. Jude Donor '05-'06-'07-'10
Default Seat Removal Question
I am trying to remove the seats from my 73 Coupe and the the door side rear bolts on both seats are a bear. I can feel them turning by reaching underneath but they are not backing out. I believe they are stripped out. Any suggestions other than knocking the heads off and going from there?
Last edited by VetteramI; Mar 3, 2007 at 08:30 PM. Reason: trying to be more clear
Old Mar 3, 2007 | 08:21 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Could be like mine were. Check under the car where the bolt goes through the floor and see if there is a nut on that bolt that is turning. This was present on 2 or 3 of my seat bolts. I went back with Grade 8 bolts, washers and nyloc nuts. Should never have any problems out of that
Old Mar 3, 2007 | 08:22 PM
blctalon's Avatar
blctalon
I clicked on this link cause I just removed both seats out of my '78 yesterday and reinstalled today. I guess mines a bit different cause the 4 bolts are all on the inside. I would however suggest a way to apply pressure to the underneath side of the bolt, then attempt to unscrew it. I've removed stripped bolts this way before, but depending on the application and room, it may/maynot work for you. GL.
Old Mar 3, 2007 | 08:35 PM
LYLE's Avatar
LYLE
I hold them underneath with an open end wrench between the metal plate and the fiberglass.
Old Mar 3, 2007 | 08:40 PM
gyopp's Avatar
gyopp
The outboard rear bolts on my 77 seats had nuts on the bottom and no evidence that there had ever been threaded holes.
Old Mar 3, 2007 | 08:43 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
My '73 was the same way. Both rear outer bolts had nuts under the car. Looked like it was made that way.
Old Mar 3, 2007 | 08:46 PM
VetteramI's Avatar
VetteramI
I felt underneath and didn't feel any nuts. Has to be something though. I will check again tomorrow. Thanks everyone
Old Mar 3, 2007 | 09:20 PM
strokervette's Avatar
strokervette
On my 78 there are nuts welded to the floor pan support and I had one bolt that gave me trouble and ended up breaking off the head. I soaked it with penetrating oil for awhile and grabbed it from underneath with locking pliers to turn it. I found it easier to spin it back and forth at first to clean the threads and then end up working its way out to the bottom.
Old Mar 3, 2007 | 09:27 PM
Johnny_Johnson's Avatar
Johnny_Johnson
Default Should be a tapped plate under the body.
The factory used a tapped plate under the body that was held in place by rivets. See part number I-1204 at the Zip web site. From all the comments these must have a history of failing. That bolt on my '73 also just spins and I haven't gone to the trouble yet of crawling under the car to what's going on or what Bubba has done to it. (I've got plenty to keep me busy on the upper side.)
Later,
Johnny
Old Mar 3, 2007 | 09:55 PM
SEVNT6's Avatar
SEVNT6
Mine has square nuts like this on all eight holes and it's factory....
Old Mar 3, 2007 | 11:14 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Thier hiding beween the frame.
Oh there are nuts hidding between the frame and floorpan. I've removed them a couple times but the first time i soaked them awhile with penetrent. Used a open or box end wrench but working by myself i taped the wrench onto nut and moved it to were it would lodge itself as i turned the bolt above to loosen (well and again to tighten when replacing seats). I have a long and thin open-end wrench in my craftsman tool set that does this job usually but have used normal combo wrench here too.
Just another awkward job that seems to get easier the more i do it. Yea, i don't know why some plate nuts aren't there but plenty of parts just ain't easy to work on in the C3.
Oh BTW u will need to slide the seat all the way fwd to access the rear bolts then all the way rear to get the fwd bolts. Funny but i can reach the front nuts to back up the wrench to turn bolts from the top.
Hope this helps.
cardo0
To Seat Removal Question
