Front end troubleshooting.
Old Mar 4, 2007 | 06:21 PM
jetdoc's Avatar
jetdoc
Default Front end troubleshooting.
Wow, finally put my car on the ground for the first time in about 3 or so...it was nice to drive it again.
I will post some pics soon, really didn't do anything major, just the front sway bar links, the rear pinion bushing, which BTW seems to have fixed the clanking when going into reverse, thanks everyone... .
Just mostly taking things apart and checking things out...trying to detail some too. I had the door panels off, most of the interior panels,bled the brakes, just a bunch of small work all around. Tried to take note of items that will need to be repaired in the future.
One thing I noticed was the A frame or control arm bushings didn't look to be in good shape. That said I have a few front end problems that need to be addressed.
When driving and you let go of the steering wheel it wants to go left, even more so when you hit the brakes.
The ball joints looked good, when I had it in the air and did the tire movement deal there wasn't any play, so is the above a sign of control arm problems?
I have some other clanking when going over bumps, I will have to figure out what that is too.
Old Mar 4, 2007 | 06:29 PM
dannyman's Avatar
dannyman
Same thing happened to me. Pulled to the right, though. We all know what happened then; started the frame off resto!!!
Alignment time.
Old Mar 4, 2007 | 06:37 PM
jetdoc's Avatar
jetdoc
What are we talking here danny, frame off or front end alignment?
Old Mar 4, 2007 | 06:52 PM
dannyman's Avatar
dannyman
Your call! You know you have an issue with front end bushings and an alignment will correct the pull to the left.
My answer is change the bushings and get an alignment.
Old Mar 4, 2007 | 06:55 PM
The3's Avatar
The3
Carefull on the suspension. I'm rebuilding mine and had to replace just about everything including the fasteners. While I was at it I replaced the engine. C3 Corvettes are like old sweaters; once you pull that loose string the whole thing unravels. Good luck.
Old Mar 4, 2007 | 07:19 PM
jetdoc's Avatar
jetdoc
The3, great analogy about the sweater, .
Old Mar 4, 2007 | 08:47 PM
jetdoc's Avatar
jetdoc
Don't know if I want to get into the change out of the bushings? Don't have the proper tools I think.
Old Mar 4, 2007 | 09:29 PM
cchristo's Avatar
cchristo
I've done mine without special tools. I went with the poly bushings and new cups. biggest problem I had was getting the springs back in. Those can be dangerous.
Old Mar 4, 2007 | 09:34 PM
Kenny Bonnell's Avatar
Kenny Bonnell
I agree !! I am putting a new cam, heads and intake on and while having the radiator out I looked at the bushings in my A arms and now I am going to rebuild that, oh yes and I forgot when I pulled the radiator, the support looks pretty rusty. Just money and time, but I love my C-3.
Old Mar 4, 2007 | 09:35 PM
The3's Avatar
The3
You can replace the bushings without replacing the bushing housings.
Old Mar 4, 2007 | 09:44 PM
jetdoc's Avatar
jetdoc
christo, didn't know the springs had to come out...The3, can you explain a bit more friend? Do you still have to remove the springs by the way you're saying?
Old Mar 4, 2007 | 09:45 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Glad the clunk in the rear end is fixed. Now, the pull is most likely the alignment, caused by bad bushings like everyone is saying. But it could also be the control valve needs balancing. One way to check this is put the front end on jack stands and start the car. The wheels should stay pointed straight ahead. If they move to the left, you need to balance the control valve.
Old Mar 4, 2007 | 10:08 PM
jetdoc's Avatar
jetdoc
Hey Eddie, I already had it on jackstands and had it running several times, with tires on sometimes and the tires always stayed straight.
Guess its bushings, yikes....I'm almost wanting to have a shop do it as I've spent so much time under the car for the past 3 weeks, I dunno. Maybe in a few days I will miss being underneath it and do it myself.
Old Mar 4, 2007 | 11:02 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I'm going to print that, frame it, and hang it in the garage
Restorod '79's Avatar
Restorod '79
You may have a little rotor run-out on your left front. That can pull, and applying the brakes can make it pull more. Just a thought.
In my opinion, A-arm bushings are not as critical as ball joints and tierods. They may look like hell, but as long as they are settled in and don't have obvious play, they wont affect straight-line tracking as you have described.
Old Mar 5, 2007 | 10:59 AM
jetdoc's Avatar
jetdoc
Thats a thought, thanks.
Old Mar 5, 2007 | 11:15 AM
dannyman's Avatar
dannyman
Tire air pressures the same on all wheels? I kick myself when I forget to go to the most basic causes. Low air left front will definitely pull left.
To Front end troubleshooting.
Old Mar 5, 2007 | 12:30 PM
my2nd78's Avatar
my2nd78
I had the same trouble. I tried the steering control valve air pressure and alignment. I even tried swapping the front tires. I ended up doing a full rebuild of the front end suspension(I already rebuilt the rear). Don't forget to check the rear. If you have an alignment problem in the rear it can cause the rear to walk out causing the car to go left.
Old Mar 5, 2007 | 05:20 PM
jetdoc's Avatar
jetdoc
Hey danny, yes the pressures are the same, thats the first thing I tried, thanks though.
Old Mar 5, 2007 | 05:26 PM
jetdoc's Avatar
jetdoc
Wow my2nd, nice job....bet that wasn't cheap or easy.
