Front end troubleshooting.
Take a look at my uppers.
I rebuilt the upper and lower control arms last weekend. It was a lot of work but well worth it. I bought my own 12-ton hydraulic press because the cost for a machine shop to install new cups exceeded the tool cost. The shops around here didn't exude confidence in getting the job done so I took it on myself. If you need anymore info let me know. SF The3
Yeah, the springs have to come out. I don't think it's possible to do it any other way. I studied the setup for the longest time, trying to figure out if it was in any way possible to change them out without removing the springs. I couldn't see a way......maybe someone else has.
In any case, other than the springs, it really isn't that complicated of a job. It was a lot of work though, but absolutely worth it.
Several years ago, I paid to have someone do it. I went with the rubber bushings. Since then, I developed a PS pump leak and it deteriorated the bushing.
I decided to do it myself, with poly, in conjunction with the Steeroids.
Lots of sweat, a little blood and two days later, she was back on the road.
I was just going to replace the original shocks with Bilstein Sports (yes, they were the original AC delcos stamped 7-1979
) and low & behold, "well lookie here, I have worn & loose bushings & since my steering box is pretty loose, I may as well get that taken care of."Now, over a month & many dollars later, I ended up replacing the steering box, power steering pump, power steering control valve, front end bushings & fuel pump. Oh, I also had the 4 wheel alignment done to make sure it's all pointed in a straight line.
Jeepers, this damn thing is gonna put me in the poor house
But, it does handle great (really great actually) probably better now than when it did right off the factory line.
Next...the interior:o
