1977 door problem
Old Mar 4, 2007 | 08:21 PM
garay77n84's Avatar
garay77n84
Default 1977 door problem
my son's 77 vette door just messed up today,it doesn't open from the inside, it opens good form the outside, my ? is would it be the lock mechanism on the door striker or the one on the pull handle on the inside door panel?
Old Mar 4, 2007 | 09:28 PM
77BuffaloVet's Avatar
77BuffaloVet
Sounds like the rod broke, bent or dislodged. Take the door panel off and you will see a rod running diagnal from the inside handle up to the lock mechanism. The end is adjustable if it is not broken.
Good Luck
Old Mar 4, 2007 | 11:00 PM
garay77n84's Avatar
garay77n84
Good Luck
thanks ,just came in the house ,took it all apart it was dirty needed to be cleaned
Old Mar 5, 2007 | 01:55 PM
77BuffaloVet
glad you got it fixed...was going to add that there is a screw on the outside of the door just below (or above...can't remember)where the latch is, which holds the mechanism in place. If that screw comes lose the whole mechanism will move when the handle is pulled and the door won't open. However...if cleaning was all you need, congrats!!!
Chris
To 1977 door problem
