Car doesnt' shut off
Old Mar 4, 2007 | 09:48 PM
wagonerjim's Avatar
wagonerjim
Default Car doesnt' shut off
I have a 1980 L48 Coupe and when I turn off the car, the engine doesn't cut off immediately. It usually takes a couple of seconds like the carburetor wants to stay running, but will eventually shut off.
It doesn't do this all the time, but what causes it to do this at anytime?
Does anyone have a fix for me?
Old Mar 4, 2007 | 10:19 PM
wombvette's Avatar
wombvette
Idle too high, too much fuel and air, dieseling.
Old Mar 4, 2007 | 10:47 PM
JoeRags's Avatar
JoeRags
Do a search for "run on" or dieseling. I believe there may be some answers out there for you.
Old Mar 5, 2007 | 07:44 AM
1Z87L8's Avatar
1Z87L8
diesling can cause engine damage, until you figure out what it is assuming its an automatic i suggest leaving it in drive with your foot on the brake then shut the ignition switch off.
sorry i dont know what the secret is for a 4 spd.
Old Mar 5, 2007 | 09:07 AM
jdp6000's Avatar
jdp6000
It run-on. Usually caused by bad gas....watered down. Specifically low octane. Try switching gas stations.
Another cause is slightly over advanced timing or bad knock sensor(not sure if you have one).
Jim
Old Mar 5, 2007 | 10:52 AM
lars's Avatar
lars
Lower your idle speed. If you have an anti-dieseling solenoid on your carb, set it up correctly and drop the idle speed screw on the carb so that the solenoid is holding the idle speed and cutting the throttle upon engine shut-off.
Old Mar 6, 2007 | 12:11 PM
mrowpolitron's Avatar
mrowpolitron
What is the correct RMP when the car is in park and ideling? Does anyone know?
Old Mar 6, 2007 | 01:24 PM
lars's Avatar
lars
Whatever rpm is comfortable and that keeps the engine idling reliably. The rpm depends on the cam you're using. Run the lowest idle that keeps the engine idling consistent and reliably. For a near-stock application, you should be around 650 in drive. If it diesels, drop it to 600.
Old Mar 6, 2007 | 02:36 PM
1B.DZ's Avatar
1B.DZ
Is your cam stock? If so, I thought it was 650-700, right?
I can't exactly remember what my problem was when my car was dieseling, but it was either a vacuum leak or bad timing. Probably both in my case. Hope you find out what it is.
Josh
Old Mar 6, 2007 | 11:54 PM
King Lear's Avatar
King Lear
Veteran
Mine used to do it and it was because the alternator and my coil wire were in the same circuit. They engine would diesel while the alternator was winding down. I ran a new coil power wire to the fuse box, put it on a 12v+ source turned on with the ignition key. Never did it again.
Old Mar 7, 2007 | 11:55 AM
jimvette999's Avatar
jimvette999
Are you running electric fan/fans?
Old Mar 7, 2007 | 12:43 PM
77-L48's Avatar
77-L48
I once had a car I put electric fans on the radiator. When the fans were running and I turned off the key, the engine would still run until the fans slowed down. The fans were sending voltage over the electrical system while they were slowing down and the HEI had enough voltage to keep going for a few more seconds.
Old Mar 7, 2007 | 01:54 PM
dgruenke's Avatar
dgruenke
Based upon the responses, I assume that you are experiencing run-on, where the car wants to turn off, but it stumbles around for a couple of seconds. If so, the above responses should be great.
However, you just stated that it keeps running. Is the engine stumbling after you try to turn it off, or does it run fine for a couple of seconds after you turn the key off? IF it runs fine, and just takes a couple of seconds to shut off, you may be looking at something else, such as the ignition switch.
To Car doesnt' shut off
