1979 heater control problem
Old Mar 6, 2007 | 11:48 PM
westlawn2929's Avatar
westlawn2929
2nd Gear
Default 1979 heater control problem
i have a 1979 corvette. the heater is stuck on the floor it will not move to vent or dash. i just rslpaced the heater core and still have the glove box out, all lines are back together. is there a trouble shoot guide any where.thank you
Old Mar 7, 2007 | 01:15 AM
Big2Bird's Avatar
Big2Bird
Yes. In the Helms Shop Manual.
Old Mar 7, 2007 | 08:42 AM
jdp6000's Avatar
jdp6000
The mechanism that directs the flow is behind the guage cluster. Its the vaccum controlled part of the switch that activates it. I'll see if I can find a diagram.
Two threads with diagrams..
http://forums.corvetteforum.com/show...ontrol+diagram
Jim
Old Mar 7, 2007 | 08:49 AM
Ganey's Avatar
Ganey
I wrote this up awhile back for this problem.
The problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default. Very safe bet the problem is 1 OR 2:
1) The vac. line from engine is damaged from heat - a small plastic tube that goes in below the hood alarm switch into wiper valley. Replacing most of engine side w/ hose will fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease or vasoline to fix.
3) If you have a heater, the small vac. tube to heater hose valve underhood probably also needs replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends.
Old Mar 7, 2007 | 09:20 AM
Blue79's Avatar
Blue79
Thanks for the tips and no offense taken!
Old Mar 7, 2007 | 10:01 AM
westlawn2929
2nd Gear
thanks for all the help, now the fun starts
To 1979 heater control problem
