when mobil 1 is not enough...
Dave
Dep
http://www.demon-tweeks.co.uk/produc...e=CAS1948/7184
i dont know if you remember, old racing cars used to live behind them a very characteristic burnt castor oil smell...this might be something to look for, the only con is that this oil must be changed every max 400/500 miles...in a full racing car, at every race.
-You have to measure the temperature of the oil, not just guess at it. Synthetics tend to look thinner.
-Synthetics break down at a higher temp than mineral mixes.
-When multi oils break down initially, it will be to their base viscosity (a 10w40 will be a 10 at high temps)
-The viscosity required is determined by the engine clearances, with a good rule of thumb being to have 20 to 25psi @ 190°F at idle.
-Good oil flow takes heat away from all bearings in addition to lubrication.
-Mobil1 15w50 is the only one they make that has the additives everyone here likes so much
http://www.mobil1.com/USA-English/Mo...1_15W-50_.aspx
-You can just change the filter and add a quart after every race. The cleaner the oil the better.
-Most Important
Don't listen to a bunch of opinions only.
Take an oil sample and have it analysed at a lab and have them translate it for you. In comjunction with recording oil temps this will tell you what to do, viscosity, type, change interval, necessity of a cooler, oil pan and windage tray.
spend the 200 bucks. It'll be worth it. Not a whole lot of downside.
Panic, do you have an oil temp gauge? If not that would be a good investment too. How hot did the oil get?
i dont have an oil temp gauge but i think i need one, together with the oil cooler, i have one on the tvr and it's a pretty easy comodity to fix and run...any bolt in brand to buy specifically for C3s?
The only way to know what is going on is to install a gauge in your oil pan. That way, you know the exact temp.
What is "Hot as Hell"? Anything over 212 degrees F will burn the living daylights out of you and that is just where you want the oil temp to begin as you need to boil all the moisture out.
If you routinely drive for 30 min at 5500-6500rpm, you have a racing application and need an oil cooler. The oil will get hot and need to be cooled. If you just did that sort of driving on a lark, then skip the cooler.
I ran Mobil 1 15W-50 in my SCCA GT-1 Corvette for many years. The reason I switched from mineral based to synthetic was based on internal engine component measurments after a season of running.
Mineral oil always allowed the internals to wear. You could measure it on the crank, pistons, cam, etc. With the Mobil 1, the wear just stopped. I'll bet that a racing application put a lot more strain on that oil than any street driving you could come up with. Did I have an oil cooler on that car, YES. But the throttle was either wide open or shut.
Install the Mobil 1 15W-50 and be happy you have the best protection that you need in a street driven vehicle.
Bob
There is one school of thought that suggests that the only difference in synthetic oils vs. petroleum oils is that the synthetics typically have a better additive package. This statement is only partially true. Synthetics almost always do have superior additives than petroleum oils. While this does add to the cost of the oil, it also enables the oil to last 3-5 times longer than conventional oil. The synthetic base stock however, is of paramount importance in the ability of a synthetic oil to flow at cold temperatures and withstand greater amounts of heat over significantly longer periods of time. Petroleum base stock molecules are long carbon chains that are sensitive to stress and heat. Additionally, various paraffins that are contained in all petroleum products regardless of how well refined they are, cause oil to jell like a syrup at extremely cold temperatures. At the other end of the temperature spectrum, high engine temperatures and heavy loads (as typically found in towing or racetrack applications) cause these chains to break down and the base stock actually boils off causing a change of viscosity and the formulation of sludge. This can happen at temperatures as low as 230º F and by 250º F many petroleum oils are suffering significant breakdown. Synthetic oils on the other hand are engineered specifically to provide all the lubricating properties that natural oil possesses, but none of the cold thickening or hot thinning properties of petroleum oil. Synthetics are made up of uniformly shaped molecules with shorter carbon chains which are much more resistant to heat and stress. Synthetics can withstand temperatures of 300ºF all day long and still protect your engine. In fact the American Society of Testing Materials (ASTM) standard wear resistance tests are conducted at 302º F. In this test synthetic lubricants far out perform petroleum lubricants by factor of four to one and greater.
http://www.firstfives.org/faq/oil/oilartcl.html
I'm outta this thread. I already see where it's heading
Dep
I just recommended Redline in another thread, I'm beginning to sound like a rep.
And you have a TVR?! Post pics!
