I have an aluminum intake and one of the bolt holes appears to be stripped. I noticed it was leaking coolant from the water gooseneck, I tried to tighten the bolt and one of them won’t tighten.
What are my options for thread repair on an aluminum manifold?
A helicoil would be easiest. I have also seen some stainless steel threaded inserts where you drill the intake, tap it and screw this in. It is threaded inside and out like a threaded plumbing bushing. Search!
63mako is right. Helicoil is an easy fix and most machine shops can do it in about 5 minutes. I have an aluminum L-88 manifold that has one of the carb mounting bolts helicoiled. However, the thermostat housing may not be as easy a fix. Not a lot of meat in that area for the coil to grab onto. And if antifreeze did any damage to those threads, it's even worse.
if you take it to a machine shop have them put in a timesert rather than a helicoil. they are stronger and they last longer. we used them at the harley shop when we had thread problems on the motor cases.
You have 2 options. The quickest and easiest is to put a HeliCoil in it. It willl last forever. You can get a HeliCoil thread repair kit at any NAPA store for about $35 and do it yourself. You'll then have the tools in your toolbox for the next time you strip out another thread.
If the thread needs to be a heavy duty repair, use a Keensert. A Keensert is a solid threaded insert and has a pretty heavy wall thickness. These are used for extreme duty applications. Keenserts are available through McMaster-Carr and Carr-Lane.
This aint NCRS accepted, but I got a 3/8 stud and coated it with JB weld and threaded it into the hole (freebie intake). Did this on my street/drag car Nova 2 seasons ago and never had a problem yet.
Thanks, it looks like the Helicoil is the way to go. Hopefully this will finally put an end to my coolant leak.
The Helicoil will fix the bad thread. But if the hole broke thru to the water passage, it will leak around the bolt shank and out the hole in the water inlet housing. Either put some JB Weld in the bottom of the hole before you Helicoil, or use the stud idea mentioned above to seal it up.
