A bit hesitant..
Old Mar 13, 2007 | 04:07 PM
craigbaker's Avatar
craigbaker
Default A bit hesitant..
hi guys,
Whenever my I start up my '76 Vette, it takes a couple of attempts to get the car to idle. Also, once I put it into drive, it tends to be really hesitatant (i.e. likely to stall) for the first few minutes or so. Once I've got the revs up it's fine, and I only get this problem when I'm cranking from cold. I reckon it's a carb issue, but does anybody else have a similar experience? Hopefully a cheap fix!!
Thanks,
Craig
Old Mar 13, 2007 | 04:42 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
(I suspect it's a choke problem)
Old Mar 13, 2007 | 04:53 PM
lars's Avatar
lars
You need to set up your choke correctly.
Old Mar 13, 2007 | 05:13 PM
Red70vette's Avatar
Red70vette
I have a similar problem and am working on getting the choke set up properly. Here is a great article that should help. I haven't tried it yet as it is my next project. I ordered a new choke spring and am awaiting its arrival.
http://www.vetteclub.org/TechnicalTi...ke%20Setup.pdf
Hope that helps. Let me know how it works for you.
To A bit hesitant..
