Distributor Choices.
Old Mar 15, 2007 | 03:58 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by KENS80V
If you use the Corvette fuel rails the schrader valve has to be removed as it bumps into the side of the smallcap HEI. You can grind most of it away and then weld the remaining hole closed. I then drilled and tapped the passenger side fuel rail for a TPI style thread in schrader valve. You can find these easily at the local wrecking yard. They are used on many different GM cars.
Ken
That's great advice...I'll check that out.
