Checkballs TH400
Mar 16, 2007 | 04:57 PM
Checkballs TH400
Whats a good way to keep the checkballs in while installing a shift kit. THanks
Mar 16, 2007 | 05:06 PM
I used lots of Vaseline...
Mar 16, 2007 | 05:57 PM
Far be it from me to question another man's use of Vaselline but...
There is assembly lube specific for transmissions.
Mar 16, 2007 | 06:18 PM
I thought Vasaline would clog the valve body up. Can you get the assembly lube at most parts stores?
Mar 16, 2007 | 06:29 PM
Vaseline works great. Been using it for 30+ years without a problem. As hot as the ATF gets, it disolves almost immediately, and it doesn't have any by-products to harm the seals. If it makes you nervous, just change the fluid after a short while.
Hans
Mar 16, 2007 | 07:24 PM
Quote:
Originally Posted by
Wrencher
Hans
I stand corrected.
Mar 16, 2007 | 09:51 PM
I just finished installing a Trans-go shift lit and they recommend vaseline for holding the check ***** in place.
Mar 16, 2007 | 09:57 PM
There is some pink stuff out there, but at $12.00 for a butter tub of it, vaseline works fine.
Mar 16, 2007 | 10:03 PM
2024 C3 of the Year Winner - Modified
Vaseline
Go with the vaseline, put a B/M shift kit in around 1977 and it worked fine.
Mar 16, 2007 | 11:09 PM
I've used regular bearing grease(not the type for disc brakes), and haven't had any problems
Mar 17, 2007 | 12:20 AM
The transmission repair guys at Allison Transmission were given Vaseline in 10 lb. cans....used a bunch of it on auto seals, checkballs, etc.
