Stroker crank questions
If you get the forged versions, they are internal balance.
Good luck!
If you go to the time and effort of building a motor that will see high RPM and upgraded HP why use a cast crank and hyper pistons? Even the low powered L82 had forged pistons, forged rods, forged crank and 4 bolt mains. These were lucky to put out 260 flywheel HP and had a 6000 RPM redline.
The bone-stock GM 400 crank is a much more reliable crank - and better quality - than the cheap aftermarket ones. There are some good expensive aftermarket cranks that are good, but for a reliable budget build-up, find a standard-sized 400 crank rather than the cheap aftermarkets. A properly prepped stock 400 crank will rev reliably through 6500, and will easily take 500 horse. External or internal balance is no big deal.
But I've only been doing this for 30 years, so I probably don't know what I'm talking about.
