I was driving my 78 this weekend and I started to hear a low clattering noise everytime I accelerated.
Then the noise started to get louder and louder.
I turned around and drove home slowly.
Any one who has had this experience before?
Am I looking at a motor rebuild?
Guys..
I would be the happiest man if the clatter was caused due to an exhaust leak.
Do you think exhaust leak would develop slowly as it did in my case?
How do I check for exhaust leak?
Chock wheels..set emerg brake...put tranny in neutral or park....start engine, open hood and listen at manifolds...
Also,take a long wood dowel and listen with you ear with other end probing engine block side below heads for internal noises...
What is your oil pressure at idle ???
Guys..
Depends on how the exhaust leak is developing. Just this weekend I fixed an exhaust leak that had slowly been getting worse and worse, and like zwede said, it did sound pretty metallic.
I looked for cracks in the manifold, didn't see anything obvious. Jacked it up and found where the manifold attaches to the midpipe there was a good 1/4" gap. I loosened up the retaining bracket and found the metal gasket there was broken in half and crushed. Got a new one (which was a bit bigger, making fitting the pipe back on to the manifold at a bit challenging), put it in and it made a world of a difference.
GM didn't put gaskets between the exhaust manifold and the heads, I don't think it's too uncommon for gaskets to be on there though, as people will often put them on if they had removed the manifolds. If that's the case, could be the gasket has been going bad. I've also read that using gaskets can promote manifolds to warp. Even if they are slightly warped, using a new manifold gasket can fix it.
Even if it's not the problem, It's worth checking for exhaust leaks, doesn't take too long and it can be a quick thing to rule out!
Raj
It could be any number of things. most likely culprits in my experience
exhaust leak, preignition (pinging), Valve clatter
You didn't mention if it was only under acceleration, under hard acceleration, or all the time.
Also, does it backfire if you back off the gas suddenly? If it does, definite exhaust leak. If it doesn't that does NOT rule out an exhaust leak.
Most are easy to fix once you determine the cause.
Start by making sure the car is securely "parked". In park or neutral (manual trans), parking brake set, wheels chocked. Start the engine and open the hood to listen for where noise is originating.
You can make a mechanics stethoscope with a piece of tubing. Hold one end close to your ear and move the other from one are to another under the hood until you find the source.
If the clatter is next to exhaust manifold at heads replace exhaust gasket.
At transition from manifold to pipe replace exhaust donut
under valve covers, remove covers and check valve adjustment
Only under hard accelerations CHECK TIMING and adjust
Initially it was only under hard acceleration.
Then it started to get louder and persisted all the time.
It does not backfire. Instead the sound was very persistent and loud.
However I noticed that it kind of stops if I accelerate in a higher gear (4th) at lower speed.
Well is it the stock manifolds.. If so check for the heat riser valve on the passanger side of the motor. I know mine is broken so when i get the rpms up it pings because the flap is opening and closing.right at the end of the manifold see if you can easily move the heat riser... Sounds like the same problem i have who knows...
