Kinda forgot to mention a cpl things. Its a 78 and its the top oval part thats loose. The base is solid. What I mean by oval is the part that the mirror itself sits in.
Thx in advance !
don't know if it would work on an exterior mirror, but this is what I did on my interior one: saved some of that sticky-glue-crap that comes on the back of a new credit card (holds it to the paper, but peels off with no residue). Then I took apart my mirror and put a thin layer of this sticky stuff over the ball pivot joint and re-assembled. It used to drift all over the place, now it holds it's position but is also adjustible if necessary.
FWIW.
You can remove the glass by soaking the mirror head in lacquer thinner or gasoline (careful!) overnight. Use enough fluid to cover the head. When it comes apart, you will see where the looseness is coming from. The best fix is to make a thin metal shim to put under one {or both} rivets. If you try pounding to tighten the rivets, you may ruin the head. After tightening, use RTV on the "posts" and lay the glass in. Position the head with the glass up and level with no weight on it [to hold it down]. Should be OK.
He's talking about the bigger oval mirror that comes on the 78-82 Vettes. My 81 is loose between the oval part that holds the mirror and the base that attaches to the door. THAT is what TortureTest is trying to tighten...not the old style chrome mirror. What's the remedy for those?
The one on my black '81 is not chrome. It is body color and has a large oval top/housing that holds the mirror & adjustment assembly. It has a base that attaches to the door that is also black. Between the base and the oval housing is where mine is loose. Anyone know how to tighten this style mirror?
Nobody, you are right on the money.....its the two piece system. I still think I might just find some way to like adhese it somehow, need some secret sauce that'll stick metal to metal....
