Radiator Flush: Any Tips?
Old Mar 22, 2007 | 09:10 AM
Wuttin's Avatar
Wuttin
Default Radiator Flush: Any Tips?
Team,
79 L82. Drained stock rad to replace the lower hose and thermostat. Heater is off line and both feed lines are plugged at the intake and water pump. I want to flush the system and refresh the anti-freeze. My plan is to just open the fill cap and the drain petcock on the radiator and let clean water enter and exit the system with the engine running. After it runs clear I'll stop the engine and drain as much as possible, then fill it with half of the full system volume with AF and top off with clean water. Am I missing anything? What is the volume of the radiator core and lines and do I need to adjust for that when adding the AF?
Thanks, Steve
Old Mar 22, 2007 | 10:24 AM
noonie's Avatar
noonie
here is a link to an older thread describing the proper flush materials
http://forums.corvetteforum.com/show...ghlight=oxalic
Here is a link to the GM TSB Instructuions for the proper proceedure. Just use the parts that apply.
http://www.geocities.com/b_gillie/TSB990602012.htm
Be sure to do the block plugs and use distilled when done.
If you thoroughly use this proceedure once, then a simple drain and refill can be done yearly to replace the SCA's and proper pH.
Old Mar 22, 2007 | 11:37 AM
Wuttin's Avatar
Wuttin
Excellent noonie...thanks for the links,
Steve
Old Mar 22, 2007 | 02:01 PM
7T1vette's Avatar
7T1vette
I didn't go to the site referenced above, so this may be duplicate info:
If the radiator has been in service a long time without proper maintenance, you want to put radiator CLEANER in it, rather than to simply flush it. Flushing gets loose material and "gunk" [old antifreeze, etc.] out....but it won't get scale, etc. off of the fin surfaces. Those deposits are what keeps your radiator from cooling efficiently, and they need to be eliminated. Buy the radiator cleaner and follow the directions on the container. This is a 3-4 day cleaning while you operate the vehicle. I can't tell you how much difference this made in my car after I purchased it. Hope this helps.
Old Mar 22, 2007 | 02:35 PM
Wrecked82's Avatar
Wrecked82
Several years ago, I had read elsewhere to use CLR in the radiator as a quick flush. People here told me don' do it - its too caustic. I did it anyway. Within 6 months, the water pump had to be replaced and the radiator started leaking and was replaced. Use the proper commercial flushes/cleaners, not some home remedy.
Old Mar 22, 2007 | 07:01 PM
7T1vette's Avatar
7T1vette
Good advice. The radiator cleaner is made by the same folks who make the radiator flush [Prestone, I think]. You can buy both at any of your local auto parts stores.
Old Mar 22, 2007 | 07:11 PM
Shark Mann's Avatar
Shark Mann
Another vote for the radiator CLEANER. You will be surprised at what this stuff can do to an old radiator
-Shark Mann
Old Mar 22, 2007 | 10:04 PM
Wuttin's Avatar
Wuttin
Sounds great guys...how do you use the cleaner? Can I refill my "drained" system with just water and then clean or do I need to clean with a correct balance of AF in the system? The block is still pretty much filled with AF as nothing has been fully flushed yet.
Thanks again, Steve
Old Mar 23, 2007 | 02:24 AM
7T1vette's Avatar
7T1vette
The instructions are on the bottle of rad. cleaner. If I remember correctly, you drain the radiator (only), put in cleaner, fill with water. Run for several hours. Drain radiator (only) again, fill with water, run again. Drain, then refill with whatever ratio of AF you want. Not complicated and does a great job. You won't believe the "stew" that comes out.
Old Mar 23, 2007 | 04:26 AM
Prestige593's Avatar
Prestige593
If you plan on adding water and not using the pre mix 1/2 & 1/2 you will have to use distilled water. This way it is mineral free and will leave less if no deposits to corrode and block up the cleaned radiator. tap or "hose" water is one of the reasons a radiator gets clogged. Good luck and let us know how you make out. I will be doing mine as soon as the car is out of the paint shop.
Old Mar 23, 2007 | 10:30 AM
jackson's Avatar
jackson
Steve/wuttin:
Get the CLEANER ... prestone AS100 in canister ... aka GM P/N 12346500. Total waste of time to look for it at auto parts store. It has been discontinued by prestone and long before that it disappeared from retail shelves. There's still some old stock at some GM dealers ... start calling dealers NOW for GM 12346500 !
Old Mar 23, 2007 | 10:41 AM
45ACP's Avatar
45ACP
Be sure to adjust your heater controls to maximize the coolant flow through the heater core when flushing or you'll be leaving a significant portion of the system untouched to continue to plug up and recontaminate the rest.
Old Mar 23, 2007 | 10:52 AM
kdf1986's Avatar
kdf1986
Hello,
On a related question, how do you dispose of your used antifreeze? I have mine in 2 5 gallon containers, but dont know what to do with it.
kdf
Old Mar 23, 2007 | 11:40 AM
steve J06's Avatar
steve J06
Originally Posted by kdf1986
Hello,
kdf
The latest method I'm aware of is to put it in the sanitary sewer, ie. flush it down the toilet. Yeah it looks bad but flush a couple times and you'll never know it was there. That way it gets treated. The enzymes break up the glycol part and the settler removes most of the heavy metals.
steve
Old Mar 23, 2007 | 11:42 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Hello,
kdf
Feed it to the neighbors cats.
Larry
Old Mar 23, 2007 | 12:04 PM
GaryS's Avatar
GaryS
Since you are doing a complete flush, don't forget the block drains. You should have two drains, one on each side, near the engine mount. Remove these two bolts and let the block drain. There is a pretty substantial amount of coolant left in the block if you don't drop the drain bolts. Very easy to do.
Gary
Old Mar 23, 2007 | 12:52 PM
jgoglick's Avatar
jgoglick
Hello,
kdf
In my city, you can take automotive fluids to a designated location once a month for disposal (no charge). this is provided by the garbage collection outfit.
To Radiator Flush: Any Tips?
Old Mar 23, 2007 | 10:09 PM
kdf1986's Avatar
kdf1986
Thanks for the reply. I am doing a search for hazardous materials waste disposal, but all the want to recycle is used oil. I think I will keep my 2 5gallon cans and keep looking. I guess I could call the city and ask them.
kdf
Old Mar 23, 2007 | 11:20 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
My advice is to do your best to NOT use any of the radiator flushes. If the system is that bad,.....I can almost guarantee you that you will replace freeze plugs, water pump and other stuff very soon after you do all of this. All of that nice crud is also sealing over a lot od rust. When you remove it..it will soon eat through.
In my earlier days as a mechanic..it was very common for customers to come in with all sorts of issues soon after using the flush kits.
I'd do my best to reverse flush with water and call it good and hope.
JIM
Old Mar 24, 2007 | 03:47 AM
7T1vette's Avatar
7T1vette
You'll have to be the judge on what condition your radiator is in. If the antifreeze was kept reasonably "fresh", you shouldn't have a rust problem. But you will have a lime/scale problem (which the cleaner should fix). If you bought the car and it had a cruddy radiator with lots of rust in it, I would agree that freeze plug removal & replacement might be a good idea. But I would still run the cleaner through it before pulling the freeze plugs out.
