Lars, What carb base gasket do I need?
Old Mar 23, 2007 | 12:36 AM
easyasone2three's Avatar
easyasone2three
Default Lars, What carb base gasket do I need?
1972 454
with stock Quadrajet. Is this the manifold with the crossover groove that needs the three gasket setup? Thanks - John
Old Mar 23, 2007 | 09:06 AM
okinawa86vette's Avatar
okinawa86vette
Obviously I'm not Lars, but that's the type of manifold where you need to use the 3 piece gasket.
Chris
Old Mar 23, 2007 | 09:29 AM
jim2527's Avatar
jim2527
Chris
Old Mar 23, 2007 | 09:55 AM
lars's Avatar
lars
That manifold does not have the crossover - you don't need the special 3-piece gasket. Just use the standard 1/4" thick open plenum base gasket and you'll be fine.
Old Mar 23, 2007 | 12:17 PM
easyasone2three
Thanks!
Old Mar 24, 2007 | 09:48 PM
okinawa86vette
Sorry, I was mistaken, but isn't that passage between the secondary openings what indicates the need for the 3 piece gasket?
Old Mar 25, 2007 | 09:01 AM
jim2527's Avatar
jim2527
No. 3-piece gasket intakes have a channel running the width of the base in front of the primary holes
Gasket one has a channel that provides communication across the channel. Gasket 2, the metal one, has no channels and acts as heat shield. Gasket 3 provides a seal between the metal gasket 2 and the carb.
Intake: Has chaennel in front of primaries..
Gasket #1 provides HOT EXHAUST communication across channel and communication bewteen secondaries with the nickel sized hole....TOP RIGHT
Gasket 2 is metal. Blocks HOT EXHAUST GASES in front channel but allows secondary communication...
Gasket 3.....seals carb agianst metal gasket 2....
Gasket 1 you buy only in a rebuild kit...$20 (see below)
Gasket 2 you can special order from NAPA or off the 'net $7-12
Gasket 3 you can buy anywhere....$3
or Buy all 3 from Lars for $15 (gasket 1 separatly not in a kit)
Old Mar 25, 2007 | 09:53 AM
okinawa86vette
Cool, thanks for the explanation and pics.
Guess I'm still learning a bit on these q-jets.
C
To Lars, What carb base gasket do I need?
