bench bleeding
Old Mar 24, 2007 | 08:28 AM
jnb5101's Avatar
jnb5101
Default bench bleeding
here's the story, i've finally got the m/c set on the booster and the ill fitting brake lines (ecklers) rebent so every thing lines up. i want to remove the m/c and do a bench bleed before i use my motive pressure bleeder.
after i bench bleed how do i prevent fluid from leaking out of the ports while i'm attaching the brake lines? just ignore a few drops or will it gush out and introduce air into the line? also, in the time it takes to hook up the pressure bleeder, will the fluid continue to drain out of the m/c, or by keeping the bleeders on the calipers will the air in the lines prevent this? i'm using dot 5 and don't want to do this twice-that junk isn't cheap!
Old Mar 24, 2007 | 08:43 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
It's not going to gush out or anything. It needs pressure on it to come out the ports. It will obviously have some fluid there just because of the bench bleed, but it's not going to go everywhere on you. You'll like the motive bleeder. I just got one this week and put it to use. One of the best things since sliced bread.
Old Mar 24, 2007 | 09:00 AM
LYLE's Avatar
LYLE
You can take the brake lines off and bench bleed with the pedal. It has worked for me just hook up the plastic lines and go for it. Save some time. You should get a full stroke if the rod is adjusted correct and if it is adjustable.
Old Mar 24, 2007 | 11:21 AM
carriljc's Avatar
carriljc
Default I really don't think you need to bench bleed....
with the pressure bleeder.
I've bench bled, and not bench bled, when using a pressure bleeder; and it did not seem to make a difference.
One thing I was able to do with the pressure bleeder, which I would have otherwise never done, and completely change my brake fluid...it is so easy to use, that I just kept bleeding until it came out completely clean at all the caliper ends.
Old Mar 24, 2007 | 11:28 AM
noonie's Avatar
noonie
It shouldn't be necessary to BB with a pressure bleeder.
Pro shops have been doing this since the beginning of time.
Old Mar 24, 2007 | 11:37 AM
carriljc's Avatar
carriljc
Default I was thinking that....
but since the only experience I have is mine, I did not want to make an overly strong statement.
Old Mar 24, 2007 | 12:07 PM
noonie's Avatar
noonie
Makes changing the fluid pretty simple.
Good job
Old Mar 24, 2007 | 01:06 PM
kaiserbud's Avatar
kaiserbud
I assume the only reason for bench bleading was to get air out of the master cylinder to prevent it from being 'pushed' through the entire brake line system.
With this pressure style of bleeding it seems much easier... the only possible negative might be that you may use more fluid to achieve a full purge when bleeding the master cylinder while on the car
To bench bleeding
