Grease Fitting Location
Old Mar 25, 2007 | 07:49 PM
Rich_71Vette's Avatar
Rich_71Vette
Default Grease Fitting Location
I performed the first Oil/Filter change and greased the front end fittings since buying the car a little over a year ago. Is there a diagram someplace to show the location of the fittings. I got all that I could see, but want to be sure I got them all.
I have a 71 big block with power steering and AC.
Old Mar 25, 2007 | 09:07 PM
SIXFOOTER's Avatar
SIXFOOTER
Should be in the shop manual,
Upper and lower ball joints = 4
both Tie Rod ends, both sides = 4
Idler arm = 1
PS valve = 1
PS Cylindar = 1
I think thats all of them
U joints = 6 maybe
Old Mar 26, 2007 | 12:00 AM
chris75stingray's Avatar
chris75stingray
idler arm has 2
i wouldn't fill the pscv because it is easy to blow the seal
Old Mar 26, 2007 | 01:30 AM
7T1vette's Avatar
7T1vette
Shop manual will have the locations. Buy one if you don't have one; no Corvette owner should be without it. [Have you really driven it for a year without an oil change?]
Old Mar 26, 2007 | 02:46 AM
Greg's Avatar
Greg
Just another Corvette guy
Old Mar 26, 2007 | 07:00 AM
bashcraft's Avatar
bashcraft
If you have a manual transmission, there's one on the z-bar.
Old Mar 26, 2007 | 12:48 PM
Rich_71Vette
The previous owner changed it before I bought it (it's somebody I know so I believe this was done). I only put about 1000 miles on it last summer. Considering the mileage, should the oil be changed more often?
Old Mar 26, 2007 | 12:53 PM
Rich_71Vette
[QUOTE=7T1vette;1559538120]Shop manual will have the locations. Buy one if you don't have one; no Corvette owner should be without it. QUOTE] I did find the diagram in there after sixfooter mentioned it. The diagram is a bit vague though.
Old Mar 26, 2007 | 04:10 PM
7T1vette's Avatar
7T1vette
Organic oils will degrade with time while open to air (like sitting stagnant in your engine's oil pan). Synthetic oils don't really have that problem. I chose to change [organic] oil every six months minimum, because of that (2000+ miles per year); but I recently changed to synthetic oil for that very reason. That should extend my oil change time to once a year (unless I increase the miles).
Old Mar 26, 2007 | 06:55 PM
Rich_71Vette
Good point. What's the opinion about organic/synthetic blends?
To Grease Fitting Location
